Question Links have save color as the background
16 years 2 months ago #61409 by JzTz
I've downloaded and installed a theme, only one thing is not fine.
The bar below the bost (Consists of :
QUICK REPLY REPLY QUOTE EDIT MODERATE DELETE
Isn't getting viewed cause they have the same color as the background of the post background.
How can I edit the background of the post or the link colour?
JzTz
16 years 2 months ago #61439 by sozzled
I think it would help all of us if we knew what version of Kunena you are talking about, what is this "theme" that you downloaded (are we talking about a Joomla site template or a Kunena template?) and maybe a picture or access to your website to see the situation at first-hand. Do you think you might be able to do those few things for us, please?
16 years 2 months ago - 16 years 2 months ago #61548 by JzTz
First of all, this is placed in Kunena 1.6, so I have that version (RC2).
Picture:
Theme was something perzian / Found on the same website as this came from:
www.kunena.com/forum/111-templates-and-d...-dark-rtl-template--
As you can see on the next picture, at the example they use images instead of text:
Thank you btw for the response,
JzTz
Last edit: 16 years 2 months ago by JzTz.
16 years 2 months ago - 16 years 2 months ago #61628 by sozzled
Please contact the developer of that template that you are using and ask the developer how to make the changes that you want. We don't support that template that you're using, sorry. :(
Further, those aren't "images" instead of text in your second illustration. What you have shown is perfectly good RTL Arabic script.
