Question [Merged topic] K 1.6/1.7 - colouring categories
16 years 3 months ago #50987 by wingnut144
So I finally got K1.6 installed, but now that I'm playing with setting up categories, how do you set the different colored backgrounds, like is shown on the Kunena demo site for 1.6??
16 years 3 months ago - 16 years 3 months ago #50988 by xillibit
go into category manager, there edit a category that you want add a color, then select the tab settings and in the input "Forum CSS Class Suffix", add one of these class suffix :
* -blue
* -yellow
* -grey
* -red
* -pink
this needs to be put in docs.kunena.com, with maybe a better english
Last edit: 16 years 3 months ago by xillibit.
The following user(s) said Thank You: Moonstone
16 years 3 months ago - 16 years 3 months ago #50989 by wingnut144
Very cool....thanks!
Are admins going to be able to create their own custom codes, and color combinations??
Last edit: 16 years 3 months ago by wingnut144.
16 years 3 months ago #50999 by sozzled
I wrote about this nearly 3 months ago: see Kunena 1.6 - "Cats" (not the musical) . There's also a green colour, too. :D
Yes, the new templating features of K 1.6 will allow you to extend a range of customised colours of your own choosing. B)
16 years 3 months ago #51330 by Cerberus
please archive as this is [solved]
16 years 1 month ago - 15 years 5 months ago #57090 by Herrie
The 1.6 documentation says:
The If you make want a colour to a specific category, go in backend and go into category manager, you need edit the specific category, then select the tab settings, in the field Forum CSS Class suffix put one the following items to have the desired colour
I have the 1.60 -RC1 installed on my localhost to tst it.
I cannot find the option mentioned in my Category >> Settings (I use the dutch language but tried to translate the options/routing)
I hoped I could use this option for my variuos 'Forums' (Read categories)
Last edit: 15 years 5 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
Time to create page: 0.658 seconds
