Question own module positions
I want to alter the kunena_profilebox a little bit (bring it to the left of the private messages link)
but I cannot find the php file that contains the code
yes I am stupid, but if you can help me I appreciate it
I am using kunena 1.7.2 and have nts_revista template
does that mean it uses the default templates ones?
My general responses are:
- If this is a question about how to tailor the Blue Eagle template to suit a particular requirement, then it belongs in the K 1.7 Templates and Design category. As far as the standard module positions included with the Blue Eagle template are concerned, please read Module Positions in the Wiki
- If this is genuinely a support matter - a question about something wrong with a typical installation of Kunena or, in other words, something that's within the posting guide (printed at the top of this page) - then it's a very good idea to explain how you think Kunena may be defective and to provide us with information we can use to help you. This is explained in the the posting guide that appears at the top of this page (for as long as this topic remains in the K 1.7 Support category.
I found the logout.php file as matias said, the default one from blue eagle
and I try to place the php code from docs.kunena.org/index.php/Own_Module_Positions
but when I try to load the forum it creates a 500 error
obviously I do not know where to exactly place the code in the php file
right now the module is on the far right and causes alignment issues, I want to have the module between the profile box and the uddeim link
how it is now:
Profile box:
[avatar] | hello user-private messages [module]
Profile box:
[avatar] | hello user [module] -private messages
is that possible
What is the Joomla module that you want to insert in the profile box? Who designed this module?
This does not seem to be a support question. It's more a question about how you would like to customise the design of Kunena to your specific needs rather than something that is actually broken with the standard Kunena product. Is that about right?
*** Topic moved to K 1.7 Templates and Design category ***
