Merged Kunena menu breaks into two separate lines
14 years 6 months ago - 14 years 5 months ago #124413 by stevieb
Hi
We have just done a new install of Kunena, But the menu items go onto 2 lines although there is room for them to fit on 1
www.nalanda-monastery.eu/forum/recent
Can you advise
Last edit: 14 years 5 months ago by sozzled. Reason: Change topic icon, subject for better search relevance
14 years 6 months ago #124437 by rich
Welcome stevieb!
Your modules go beyond the sidebar. They have a fixed size
"templates/theme_church0168-4/css/template.css" line 235 and 241
change in both lines width: 265px; to width: auto;
The following user(s) said Thank You: stevieb
14 years 5 months ago - 14 years 5 months ago #124884 by Jetsfan
I have some troubles with the Main Menu of Kunena. (Index, Recent Topics, No Replies..etc)
Each time the line is wrapped at the active button into a second line. Any ideas?
www.theganggreen.de/forum/index.html
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : rt_voxel | author: RocketTheme, LLC | version: 1.0 | creationdate: May 2, 2012
Third-party components: UddeIm 2.6
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.1 | Kunena Discuss 1.7.2
Modules: Kunena Latest 1.7.1
Last edit: 14 years 5 months ago by Jetsfan.
14 years 5 months ago #124887 by Jetsfan
tried it with several templates. everytime the same result :S
14 years 5 months ago - 14 years 5 months ago #124888 by Voice4Vision
It would be my guess that you have some modules viewable while in Kunena. You can either remove the modules...or increase your template size. These would be my only suggestion. I have seen this many times, all of it was due to modules being viewable in kunena...
Sorry I can not help you further, but every joomla template is different. And if you wish to keep the Modules in place...then you will need to adjust your joomla template.
EDIT: Just saw the link in this post...so sense I see no modules as a non-logged in user. I also do not see the two-line menu in kunena. So it simply comes down to increasing your Joomla Template size, I believe it is the header that needs to be increased.
Hope this helps,
Voice4Vision
Last edit: 14 years 5 months ago by Voice4Vision.
14 years 5 months ago #124891 by sozzled
G'day, Jetsfan, and welcome to Kunena.
Typically, problems like yours are caused by a combination of two factors:
(1) How much screen width you've allowed for the display of your Joomla components - Kunena is a Joomla component - and whether there are other modules that, when displayed, reduce that width; and
(2) Whether your Joomla site template has some arbitrary rule, that affects line-breaking or padding. For example, it would be easy for me to split the Kunena menu, on this site, across two lines if I added one small change to the current definition:
#Kunena #ktab ul {
display: inline-block;
       list-style: none outside none;
       margin: 0;
/*     Split the Kunena menu over two lines
       IMPORTANT NOTE: the following line is not something THAT people should add to their site template! */
       padding-right: 500px;
In your case, Jetsfan, it's impossible to say what's going on. The menu that appears in your picture only appears for people who are registered and logged-in to your site. I do not have an account that I can use at your site so that I could use Firebug to see more.
BTW, that's a very nice design (use of colours and category icons). :)
The following user(s) said Thank You: Jetsfan
Time to create page: 0.155 seconds
