Important Fix statistic info forum bug
14 years 9 months ago - 14 years 9 months ago #117307 by clevercat
please help me to fix my forum statistic info bug
i get this error
can you give me what file i must modify, or can i change that statistic info to look like the statistic default kunena template like this
here my forum address alumni28jkt.org/forum/
Last edit: 14 years 9 months ago by clevercat.
14 years 9 months ago #117350 by Jiminimonka
Did you read this - docs.kunena.org/index.php/My_Joomla_site...kes_a_mess_of_Kunena
and can you post your Kunena Config.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago - 14 years 9 months ago #117425 by Matias
I think this is a conflict between your template and that Kunena template. Is it from Template Blender?
templates/gk_music/css/reset/meyer.css (line 7+) has rule like this:
html, body, div, span, applet, object, iframe, p, blockquote, pre, a, abbr, acronym, address, big, cite, code, del, dfn, em, font, img, ins, kbd, q, s, samp, small, strike, strong, sub, sup, tt, var, b, u, i, center, dl, dt, dd, ol, ul, li, fieldset, form, label, legend, table, caption, tbody, tfoot, thead, tr, th, td { background: none repeat scroll 0 0 transparent; border: 0 none; font-size: 100%; margin: 0; outline: 0 none; padding: 0; vertical-align: baseline; }
Remove the last line: vertical-align: baseline;
Fix may have some side effects, but fixes the issue.
Last edit: 14 years 9 months ago by Matias.
14 years 9 months ago #117427 by clevercat
Matias wrote: I think this is a conflict between your template and that Kunena template. Is it from Template Blender?
yes it from template blender, it hard to find native kunena 1.7 template with view like this template, other template is look like as stock template only difference in color
thx i will test the suggestion
