Question Kunena 1.7.1 forum - default text colour
14 years 8 months ago #116515 by Vanessa13
Hi everyone,
Please bear with me, as I've only recently started learning how to use Joomla and Kunena, although I do have some experience in simple .html sites.
My default site font is white, because the overall website has a dark background. I need to change the font colour of posts, in just the forum and blog sections, because the default is light grey, which is really hard to read for most users. I know that I need to edit the CSS code, but there are a few CSS sections I can edit, and I'm unable to find which one I need, and I'm almost clueless about editing the actual CSS, so I need help to know which parts to edit too.
Some information about my site/versions that I think whoever replies will need:
Joomla 1.7.3
Kunena forum 1.7.1
JomSocial 2.4.1
K2 blog info:
Web Server Microsoft-IIS/6.0
PHP version 5.2.17
MySQL version 5.1.38-community-log
GD image library bundled (2.0.34 compatible)
Multibyte string support Enabled
I'm using the Blue Eagle template.
Kunena CSS files available in my template manager for editing:
kunena.default-min.css
kunena.default.css
kunena.default.rtl-min.css
kunena.default.rtl.css
kunena.forum-min.css
kunena.forum.css
kunena.forum.ie7-min.css
kunena.forum.ie7.css
kunena.forum.ie7.rtl-min.css
kunena.forum.ie7.rtl.css
kunena.forum.rtl-min.css
kunena.forum.rtl.css
kunena.skinner-min.css
kunena.skinner.css
kunena.skinner.rtl-min.css
kunena.skinner.rtl.css
Thanks for the help, and please let me know if you need any further info in order to help.
14 years 8 months ago - 14 years 8 months ago #116566 by sozzled
G'day, Vanessa, and welcome to Kunena.
See the FAQ information printed at the top of this page, in particular, How do I change the colours of my template in Kunena?
Dark-themed templates are generally more difficult to work with than light-themed templates. The Blue Eagle template (without modifications) is more suited to light-themed templates. You need to change your Joomla site template CSS file to change the colours used in Kunena. Firebug for Firefox will help you do those things.
Last edit: 14 years 8 months ago by sozzled.
14 years 8 months ago #116569 by CheechDogg
If you can provide a link to your site and forums I can help you out a bit more.
If you want to change the color of the text of messages add this to your Joomla template.css file:
#Kunena div.kmsgbody div.kmsgtext {color:#ff0000;} Replace the color with your choice.
To change the color of the text for the categories add this to your Joomla template.css file:
#Kunena tr.krow2 td {color:#ff0000;}
#Kunena tr.krow1 td {color:#ff0000;} Replace the color with your choice.
To change the color of the text for the text of the Announcements add this to your Joomla template.css file:
#Kunena div#kannouncement .kanndesc{color:#ff0000;} Replace the color with your choice.
The best way to figure out what to change is like sozzled said, use Firebug for Firefox. If you want to change say the text in a certain area, highlight the text, right click your mouse and click on "Inspect Element with Firefox".
You will then be given a screen where you can see what you need to change in the css files, it will also give you the exact directory and file where that particular element is located in.
Hope this helps you out Vannessa.
[img
Find me on Facebook.
14 years 8 months ago #116621 by Vanessa13
sozzled wrote: G'day, Vanessa, and welcome to Kunena.
Hi, and thanks for the welcome and your help.
If I change the main Joomla template (am I correct in thinking that's what you mean?), will that not make the text in my site articles black, too? The articles are on a black background to fit the site's theme, so they'd be unreadable if it made the entire site black. It seems it would be easier to just change the main template to something lighter, so the black text will be readable no matter where it is on the site. I'm contemplating that, though I have to admit I really like the current dark theme. I'm going to download Firebug now, thank you. I'll give an update here once I've downloaded, installed and tried out Firebug.
Thanks again!
14 years 8 months ago #116622 by Vanessa13
CheechDogg wrote: If you can provide a link to your site and forums I can help you out a bit more.
Hi there. Thanks for all your help.
I'm going to download Firebug now and have a look. It sounds like the best bet for someone who doesn't know CSS very well! I'll keep you updated, thanks, just so you know how this turned out.
I'll try Firebug before asking for any further help, but in case you're curious, the site addy is www.vanessafinaughtybooks.co.za
Thanks again!
14 years 8 months ago #116624 by CheechDogg
Hello Vanessa. Did you try the css rules I gave you?
Yes Firebug is a very good tool to have I use it every day myself. Don't hesitate to ask questions, I have offered my help and you are more than welcomed to ask me for help even if you have not tried Firebug before.
I checked your website out and if you add the css rules above to your template's css file you will be fine:
Go to the following directory using FTP:
templates/vbooks7/css/
Open up the following file using Notebook ++ and at the very end of it add the code.
template.css
Once you have done that you can then see the changes and you will be set. Let me know how this turns out.
[img
Time to create page: 0.266 seconds
