Question Kunena Features
14 years 10 months ago #115262 by Wootah
Kunena Features was created by Wootah
Hi all,
Thanks for this amazing message board.
Here is what I would appreciate some information on.
* Template Overrides - do they work?
Actually that's the biggest question I have in terms of customising the board.
Thanks,
Mat
14 years 10 months ago #115265 by Wootah
Replied by Wootah on topic Re: Kunena Features
Reading around it appears Kunena has it's own template system and doesn't use the Joomla ovveride system? Is that true?
What is the best guide on making my own template for Kunena?
Thank you!!
14 years 10 months ago - 14 years 10 months ago #115267 by sozzled
Replied by sozzled on topic Re: Kunena Features
I haven't tried template overrides with K 1.7.x. If you know how they work, you can probably do it. Simple changes to colours, styles, etc., can easily be done by modifying your Joomla site template CSS to "override" whatever CSS styles are used by Kunena. See How do I change the colours of my template in Kunena?
Template overrides are for advanced Joomla users and are a little beyond the scope of this forum to deal with in depth.
Last edit: 14 years 10 months ago by sozzled.
14 years 10 months ago #115269 by Wootah
I found this:
docs.kunena.org/index.php/K_1.6_Template
docs.kunena.org/index.php/How_to_create_a_template_for_Kunena
As far as I can tell this is css edditing only which is fine except I was hoping to edit the php from here as well.
14 years 10 months ago #115270 by Wootah
So looking harder the default template has php code in it and the example template has none.
I copied the example template but can I copy the default template and then edit the php there as needed?
Short answer is yes. And it seems I can now do what I want in terms of editing the design of the board.
