Question How to create a module position in kunena
14 years 10 months ago - 14 years 10 months ago #115229 by daneshpars
Hi.
I am Iranian.
I put ads in between posts kunena- I searched the forums and external sites.
And a code for creating conditions for the modules found in kunena. But that description does not say exactly what part of it which files and file formats should be kunena.
Code I put in three of eight kunena file format. But in your position - do not show the module positions.
Please also check out these sites that you know which files must be edited. And where the code should be.
docs.kunena.org/index.php/Module_Positions
www.templatekunena.com/docs/index.php/ku...itions-in-kunena-16x
files template kunena:
kunena.forum-min.css
kunena.default.css
kunena.forum.css
kunena.forum.ie7-min.css
kunena.skinner.css
kunena.default-min.css
kunena.forum.ie7.css
kunena.skinner-min.css
What to do in the code file template.
kunena_profilebox kunena_announcement kunena_bottom kunena_msg_1 ... kunena_msg_n, where n = number of messages in a page
*Sorry if I put my question in this part of the forum - because it was associated with kunena template.
Thank you. ( با تشکر از شما )
Last edit: 14 years 10 months ago by daneshpars.
14 years 10 months ago #115434 by sozzled
The following user(s) said Thank You: daneshpars
14 years 10 months ago #115554 by daneshpars
What to do in the code file template kunena.
14 years 10 months ago #115555 by sozzled
daneshpars wrote: I put ads in between posts kunena- I searched the forums and external sites.
You do not need to "code" anything - in PHP, I mean - unless you are trying to create your own Kunena template. You simply assign your ad module to a module position (it's standard Joomla).
The module positions that you can assign your module to are described in Module Positions . It is beyond the scope of this forum to describe how to create other module positions in templates.
The following user(s) said Thank You: daneshpars, MiNe
14 years 10 months ago #116125 by MiNe
Replied by MiNe on topic Text Link Ads Module
I from the Chinese Taiwan, my demand function like graphical representation, whether to have the possibility? Thanks you!!
14 years 10 months ago - 14 years 10 months ago #116454 by daneshpars
persian :
در کدام فایل ، قالب کامپوننت کیوننا کد را قرار دهم.
فایل قالب کیوننا :
kunena.default.css
kunena.forum.css
kunena.skinner.css
با تشکر
english :
What file format do the code kunena component.
kunena template file:
kunena.default.css
kunena.forum.css
kunena.skinner.css
Thank you
Time to create page: 0.167 seconds
