Question Sidebar-a,b,c are laying overtop of forum output
14 years 9 months ago #114755 by atvsource
For some reason, the forum is not honoring the spacing between modules and the forum is laying underneath the sidebars.
What needs changed so that the forum does not get covered up by joomla modules?
See attached image of the cover up.
htaccess: Exists | PHP environment: Max execution time: 200 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : rt_modulus_j16 | author: RocketTheme, LLC | version: 1.6.5 | creationdate: December 12, 2011
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Forum image of the sidebar-c area
Craig
14 years 9 months ago #114757 by sozzled
Because we cannot access your website, I refer you to My Joomla site template makes a mess of Kunena . If you use Firebug (or something like it) you will quickly find out what you need to change. Alternatively, ask the good folks at Rockettheme.
Time to create page: 0.169 seconds
