Question Why won't installed templates display properly in Kunena 1.7 and Joomla 1.7.3?
14 years 6 months ago #111374 by Aftermath
Why won't installed templates display properly in Kunena 1.7 and Joomla 1.7.3? I know that Kunena is supposed to kind of match the Joomla theme, but how do I get it to look like the cool pictures of the themes that I download? i.e. Aphotic II? Website URL is aftermathguild.org .... it doesn't even look like Kunena should, imo.
14 years 6 months ago #111383 by Aftermath
Also I should mention that my Joomla template was created in Artisteer so I don't know if the Kunena menu will display properly anyways.
14 years 5 months ago #111408 by xillibit
Why are-you using a frameset ? :ohmy:
14 years 5 months ago - 14 years 5 months ago #111440 by Aftermath
Sorry, it's a forwarded domain. Go to aftermath.khadstudios.com . This is what I have with a fresh install of both Joomla and Kunena. Even using the default Joomla (atomic) template, there doesn't seem to be any css going on in Kunena.
Last edit: 14 years 5 months ago by Aftermath.
14 years 5 months ago #111479 by Matias
You're adding a frame around our CSS file, translating it to HTML page with HTML frame to our CSS file. That cannot work...
Check the source code and try to visit our CSS file.
14 years 5 months ago - 14 years 5 months ago #111493 by Aftermath
I don't understand what that means. All I did was install the Kunena components, the templates and enable them. Whatever Joomla did with adding a frame, it did on its own. Which file would I edit to fix this?
Also, why didn't any of the images install when I installed it? where do I get the images?
Time to create page: 0.235 seconds
