If you have questions about third-party templates, please use the User-written Templates
category or contact the author directly. This category should only be used for questions about templates developed and supported by the Kunena project.
I am using the template provided by my template designer, he has a template specifically for Kunena to match the look of the template. I would like to know how can I change the template color to black. I am refering to the gray for the descriptions? I tried using firebug but it lead me to the wrong file.
What do you mean, "the wrong file"? Firebug knows exactly where it gets CSS calls from.
Do you know about the minimized CSS files that Kunena uses? I suspect that Firebug is pointing you toward the minimized CSS file and you don't think that's right because it looks like no other CSS file you've ever seen.
Go to the Wiki on this site and read the entry about minimized CSS files and see if that helps your understanding.
HTH.
\dmc
Thanks for the info...I went to exact location of what Firebug listed, but I made a lot of changes to the file and nothing happen. This is not the first time..I might be doing something wrong...
I have noted a trait in all things Joomla that sometimes a change in a CSS file doesn't necessarily show right away ... I assume this has something to do with cacheing on the server side or perhaps cacheing internal to the browser being used.
Again, in an instance like this, the more specifics you provide us in the forum, the more likely we'll be able to find your problem.
