Question Problem with tabs in reddy
15 years 2 months ago #107829 by harisg7
The tabs in reddy template doesn't work and I can't edit profiles! How can I fix it this?
Also, I don't see Boardcode on new topics...
Joomla 1.5, Kunena 1.6.4, clean install
15 years 2 months ago #107852 by xillibit
I advise you to upgrade to Kunena 1.6.5 at least or Kunena 1.7.0, you have a mootools conflict somewhere, you will numerous topics on the subject by example here : www.kunena.org/forum/159-k-16-and-k-17-c...ease-read-this-first
15 years 2 months ago #107893 by harisg7
I upgraded to Kunena 1.7.0 but still doesn't work!! :(
15 years 2 months ago - 15 years 2 months ago #107899 by harisg7
I Fixed It! I removed jce utillities and enable mootools upgrade!! :)
Thank you very much for your help...
Last edit: 15 years 2 months ago by harisg7.
15 years 2 months ago #107903 by Mortti
Look like that "Reddy" -template is made for K 1.6.1 and it is not compatible in K 1.7.0? --> www.kunena.org/forum/111-user-written-te...-kunena-161-template
Ask template dev to update/check it
