Question IE7 layout problem... help appreciated!
15 years 2 months ago - 15 years 2 months ago #107049 by eadaoin
Hi all,
(I'm running version: Kunena 1.7.0 | 2011-08-29 | 5135 on Joomla! 1.5.23 Stable, and the Rockeththeme Terran Tribune template.)
When I first installed it, the Kunena main text area was protruding slightly beyond the edge of the template in both Firefox and IE8, see original.jpg attachment below.
I edited the CSS file kunena.forum-min.css, to change the minimum width value from 700 to 600:
#Kunena {padding: 0;margin: 0;line-height: 1.333em;min-width:600px;}
This worked, and in Firefox and IE8 it displays properly, see attached adjusted_firefox.jpg
However, in IE7, the width has altered, but instead of fitting the contents into the new width, it appears that the overlapping has been cut off, see adjusted_IE7.jpg.
I can't figure out which of the values in the IE CSS files to alter in order to make the content fit into the given space without losing anything.... any help would be much appreciated!
Thanks,
Éadaoin
Last edit: 15 years 2 months ago by eadaoin.
15 years 2 months ago #107196 by eadaoin
Well, I found a workaround that works for me.
I don't need the width to be flexible, as I intend to keep the 'Left' positioned modules. So, I edited kunena.forum-min.css, to change the minimum width value to a width value, i.e.
#Kunena {padding: 0;margin: 0;line-height: 1.333em;min-width:600px;} is now
#Kunena {padding: 0;margin: 0;line-height: 1.333em; width:650px;}.
Not strictly a fix, but IE is happy, and so am I :)
15 years 2 months ago #107203 by 810
please change it back. And add the change in kunena.forum.ie7-min.css
regards 810
15 years 2 months ago #107206 by eadaoin
Thanks, 810.
I did that first, which did work, but then I thought it was simpler and neater to change it in the main CSS file as I didn't need the variable width... Thanks for the tip.
15 years 1 month ago - 15 years 1 month ago #109235 by nabila1230
i have also problem All-new mail layout problem on IE7?
all-new mail layout problem on IE7
OK with classic mail
OK on Firefox
OK with my other yahoo mail accounts
problem started late 10/10/2011
messages don't show
Inbox, draft, sent, spam, trash, contact, calendar - folders show on far left
Empty, Add text on Far Right
advertisement hide arrow shows on far left
Check Mail and New show on top
search is just below that
deleted cookies @yahoo.txt
deleted cache
closed & refreshed browser
Any suggestions that plp have found to work would be appreciated
Thx
Translation Services
Last edit: 15 years 1 month ago by nabila1230.
