Question IE9 Input text fields
15 years 4 months ago #101893 by Shimei
IE9 Input text fields was created by Shimei
I'm having an issue with the input fields. The text in the input fields are not visible in IE9. I'm using the blending option and the blue eagle template. Below is my configuration report and some screen shots, any help will be appreciated.
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : js_onyx | author: Casey Lee for Joomlashack | version: 1.3 | creationdate: November 2010
Third-party components: AlphaUserPoints 1.5.13 | UddeIm 2.2
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.2 | Kunena Login 1.6.2
15 years 4 months ago #101894 by 810
Replied by 810 on topic Re: IE9 Input text fields
hi, try to remove : #Kunena input#keywords, #Kunena input#kusername, #Kunena input {
color:inherit; }
on kunena.skinner.css
regards 810
15 years 4 months ago #101899 by Shimei
Replied by Shimei on topic Re: IE9 Input text fields
Hi 810,
I removed the provided code. The username input field now displays correctly, the text is visible. The board categories from the drop down menu from the above screenshot display in the same manner (faintly visible). And lastly, the input fields for creating a post are still hardly visible (the bottom screenshot).
15 years 4 months ago #101902 by 810
same: #Kunena textarea, #Kunena select, #Kunena select:focus, #Kunena select:hover {
color:inherit; }
The following user(s) said Thank You: Shimei
Time to create page: 0.174 seconds
