Question Forum header text misaligned within box
- Mr Livered
- Senior Member
Screenshot attached so you can see what I mean - any assistance gratefully received
Thanks.
Of course, if you would rather have us look at this problem for you instead, can you please post the URL of your website so that we can look at the issue? Thanks.
Oh, and by the way ... the problem is caused by your site template. You have some template-wide rule for H2 elements that's overriding the Kunena template CSS.
- Mr Livered
- Senior Member
Is there a way of making Kunena use its own H2 elements rather than letting itself be overriden? It would seem to be simpler than making changes that might have unintended consequences elsewhere on the site. Sorry if that's a dumb question.
Liking your new avatar, by the way, but I think I shall miss the iron man :lol:
The way Joomla works is that your Joomla site template overrides everything because it's the last piece of CSS that's loaded. Yes, of course it's possible to make Kunena use it's own H2 element but in your case that's not the issue. The Kunena template doesn't contain any rule that causes the display of text to exceed the right margin. Therefore you have to insert a rule that changes your Joomla site template so this rule applies only for Kunena situation and not elsewhere on your site.
You will find the cause in one mouse-click with Firebug for Firefox. You will solve this if you know a little bit about CSS. However, while your site is sequestered the way it is, there's only one thing I can say: please see Support for PC-hosted websites (e.g. WAMP, XAMPP) .
I don't know what you have done with your site CSS definitions - and I'm only guessing that it's something to do with the rule about <h2> elements) - but you have some text wrapping or margin issues. When you have your website online and when we can see it then we can tell you. Otherwise, there's only one option: you have to figure it out for yourself. Sorry, that's the way it is. Good luck.
- Mr Livered
- Senior Member
- Mr Livered
- Senior Member
I have uploaded the website to a live server to finish the development, and I would be extremely grateful if you could offer some thoughts on how best to fix this header misalignment.sozzled wrote: When you have your website online and when we can see it then we can tell you.
Here is the link:
kratomassociation.org/index.php/forum/
