Question forum creates problem for pull down menu sub-categories
15 years 4 months ago #100937 by beyondthenet
This issue only happens on the forum page (no other pages on website):
meetyourpsychic.com/forum/index (no issues on other pages such as meetyourpsychic.com/ )
When you mouse over the top "mainmenu" categories (such as "Readings") the sub-items have a 20px gap which causes navigation difficulties.
Also, how do I remove the "Rules" tab?
Thank you
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : rt_nebulae_j15 | author: RocketTheme, LLC | version: 1.5.1 | creationdate: May 18, 2011
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Third-party components: AlphaUserPoints 1.5.13
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.6.4
15 years 4 months ago #100938 by sozzled
Try by adding the following lines to the end of your Joomla site template CSS:
#Kunena select, #Kunena select:focus, #Kunena select:hover { background-color: transparent; border: 0 0; color: #AAAAAA; padding: 0; }
For Rules tab matter, this is answered in the FAQs tab at the top of this page; see Kunena menu issues sub-heading How do I edit, hide, disable or translate menu items in K 1.6 (e.g. rules, help, search)?
15 years 4 months ago #101101 by beyondthenet
Thanks, I found how to edit the menu options (Joomla Admin/Menus/kunenamenu)
However the code you suggested did not fix the menu options. I'd be happy to give you ftp/super admin access if you want to take a crack at it.
15 years 4 months ago - 15 years 4 months ago #101102 by sozzled
The problem is not caused by Kunena. Thank you for explaining what you mean by "pull-down menu". Your site template (../templates/rt_nebulae_j15/css/template.css) has the following rule (at around line 149):
.inputbox, #form-login .inputbox, #com-form-login .inputbox, #josForm .inputbox, .component-content .search_result .inputbox, .component-content .contact .inputbox, .component-content .user input#email, .component-content .user input#name, .component-content .user input#username, .component-content .user input#password, .component-content .user input#passwd, .component-content .user input#password2 { border-radius: 6px 6px 6px 6px; position: relative; z-index: 100; }
Comment-out the z-index rule.
Last edit: 15 years 4 months ago by sozzled.
15 years 4 months ago - 15 years 4 months ago #101104 by beyondthenet
I deleted this line but it did not help:
{position: relative;z-index: 100;border-radius: 6px;}
I'm not sure how to comment out but am more confident about deleting a line :)
Thank you for looking!
Last edit: 15 years 4 months ago by beyondthenet.
15 years 4 months ago #101110 by sozzled
That last change didn't help. I was wrong. I've spent the past hour looking at this and the only thing that I can say with certainty is that there's some CSS conflict somewhere between your menu system and the Kunena component display and I can't tell what's causing it. I don't think I've ever had to admit to defeat but, on this occasion, you got me. I think you will probably have to refer this matter to Rockettheme. Maybe someone else (who hasn't been awake since 01:30 this morning) might be able to cast fresher eyes on the problem. Sorry, but on this occasion, I can't help you.
Time to create page: 0.166 seconds
