Question Kunena Forum Speed
15 years 5 months ago - 15 years 5 months ago #98761 by vinod.ostech
I have kunena version 1.6. but the speed of the forum is very slow. Whenever i click on an category or kunena page it takes lot of time to load.
i am attaching my configuration file. plz help
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 10M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.6.285) | UddeIm: Disabled or not installed
Last edit: 15 years 5 months ago by xillibit. Reason: Put correctly the report configuration
15 years 5 months ago - 15 years 5 months ago #98811 by xillibit
Replied by xillibit on topic Re: Kunena Forum Speed
You can start by upgrading Joomla to 1.5.23 and Kunena to 1.6.4 versions, and update too Kunena latest module
15 years 5 months ago #98823 by Matias
Replied by Matias on topic Re: Kunena Forum Speed
Your forum html seems to load faster than the front page, but your site crashes my FF4 before I have change to look at it. Also Chrome has issues in your site and stalls for a long time. Your basic issue is that your site is loading ancient Mootools 1.12, which causes a lot of issues in latest browsers. In addition Joomla also loads Mootools 1.2.4, which breaks up things even more.
Plugin responsible loading ancient Mootools in wrong way is Kampyle, so you should probably disable it. It works against good and documented practices in Joomla.
You should also upgrade Joomla to 1.5.23 as your version of Joomla doesn't have the latest Mootools 1.2.5 which works without issues also in the latest browsers.
You should also change avatar integration into Kunena or Jomsocial. But be aware that having JomSocial integration will cost you ~20% slower page load times.
You have other basic issue in your site: all images, javascript and css gets loaded on every page load, which also makes your site slow. Please google how to cache images (and other static files) in Apache.
