Question Some Problems (crash) with other Plugins/Components/Modules
15 years 6 months ago #95548 by robbes79
i try everything and i can't explane me this issue. Somehow effects Kunena, JA Comments and X5AJAXChat somehow the plugin puremessenger, like you can see on the picture.
I try to get now some support from all developers of the tools that causing some trouble to each other to maybe find a solution or maybe some of the community user have the same problem and got it to work.
Website: Website
I hope someone can help me.
15 years 6 months ago - 15 years 6 months ago #95558 by sozzled
G'day, robbes79, and welcome to Kunena.
Because this issue does not seem to be isolated to Kunena - it's more likely to be something incolving the mix of Joomla extensions you have installed - for example, have you written to the developers of X5AJAXChat to see if this is a known problem as far as they are concerned. I think the issue actually has more to do with whether other extensions, (e.g.X5AJAXChat uses jQuery) - interact with Joomla's Mootools Javascript library than anything else but I am only guessing.
Kunena uses the Joomla Mootools Javascript library and, if you want Kunena to work properly, you need to ensure that other Joomla extensions do not interfere with Mootools.
If you believe that there is something that is needed by Kunena to make things work for you, please read the posting guidelines printed at the top of this page and act accordingly. Thank you.
Last edit: 15 years 6 months ago by sozzled.
15 years 6 months ago #95573 by robbes79
This means jQuery is the problem because is interact with mootools?
Sorry i read it, but this is an issue of all components/modules and plugins, also included Kunena. When this is true that Kunena doesn't care than Kunena needs to be like phpBB boards as standalone. Joomla is made to use different things on one time and the hole time. This is only my opinion.
Or what i have done wrong? Or do you mean to post this to Joomla because there mootools and jQuery sucks? Sorry i can't follow you, can you please be so kind and explained it to me?
15 years 6 months ago #95579 by sozzled
jQuery works but you have to implement it carefully so that it doesn't conflict with Mootools. See Common causes of Mootools (Javascript library) issues and Kunena which explains things in technical details.
15 years 6 months ago #95609 by Matias
I think that the issue is CB, which loads its JQuery library also in Kunena, if CB profile integration is enabled.
15 years 6 months ago #95654 by sozzled
Possibly CB, Matias, but I went to the X5AJAXChat website, tried out the chat application, and I discovered that X5AJAXChat uses jQuery. I remember using another AJAX chat application (jPFChat) and that application breaks if you use any kind of Mootools. I made the decision that Kunena was more important than online chat and I got rid of it - real-time chat was rarely used anyway so it was an easy decision to make.
You could be right, Matias, but I'm using CB 1.4 on a several websites and I haven't hit any Javascript conflicts, yet. We may never know what is the cause because robbes79 has not provided us with details of his website (the link in msg #1 points back here to www.kunena.org ) or his configuration report. :dry:
