Question Issue: Timeout issues when I try to a topic
15 years 7 months ago - 15 years 7 months ago #90596 by street2k
Greetings,
I just installed K1.6, I was able to create my forums & subforums without any issues. The problem I face is when I try to create a new topic from the front end. I get a the following error:
"404 Not Found
The requested URL /forum/post.html was not found on this server.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request."
I've included my report config settings below:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : recordlabelwhite2column | author: J.Mosby | version: 3.0 | creationdate: 2011-01-08
Kunena default template details : Autumn | author: Kunena Team | version: 1.6.0 | creationdate: 2010-07-04
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.4) | UddeIm: Disabled or not installed
Third-party SEF components: sh404sef: Disabled or not installed | ARTIO JoomSEF: Disabled or not installed | AceSEF: Installed (Version : 1.5.15)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Enabled (Version : 1.6.2) | My Kunena Forum Posts: Disabled or not installed
Last edit: 15 years 7 months ago by street2k.
15 years 7 months ago #90609 by xillibit
I think your issue come from aceSEF, i advise you to use default sef integrated into Joomla!
15 years 7 months ago #90679 by street2k
I dont think that is the issue because the makers of acesef also makes a kunena converter & sef plugin for kunena but Ill try to see if it works...
Nope Im still having the same issue. Any more suggestions?
15 years 7 months ago #90680 by street2k
I figured it out... Its a K.16 is having an issue with both the joomla or acesef seo settings enabled. That sucks too because I have no clue on how tweak the htaccess file to work around this issue.
I might look into upgrading the site to Joomla 1.6 then theres a template issue...
15 years 7 months ago #90687 by sozzled
What version of AceSEF are/were you using?
