Question Serious problem in visualization of posts
15 years 7 months ago #90293 by gbastia
I tried to solve a serious problem of my Kunena forum, but without resoults. When I am logged in my site, i can access in the forum without problems, but when I am not logged I get a bug on the visualisation...
I really don't know how to solve it :(
Please can somebody can help me?
Thank you very very much :)
Gbastia
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 32M
Joomla default template details : psm | author: | version: 1.0 | creationdate: 2011-02-06
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.3)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
15 years 7 months ago #90298 by xillibit
Do you have examples more detailled ?
15 years 7 months ago #90299 by gbastia
15 years 7 months ago #90301 by xillibit
Please enable debug mode and set error reporting on maximum in Joomla! configuration panel
15 years 7 months ago - 15 years 7 months ago #90313 by gbastia
Done. I've made a copy of the site in this domain: www.trova-annunci.it I put on the debug mode and set error reporting on maximum...
Gbastia
Last edit: 15 years 7 months ago by gbastia.
15 years 7 months ago #90314 by xillibit
Your issue is the following :
Warning: mktime() [function.mktime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CET/1.0/no DST' instead in /web/htdocs/www.trova-annunci.it/home/plugins/system/vvisit_counter.php on line 95
In your php.ini file, you need to set the right timezone : www.php.net/manual/en/timezones.php
Time to create page: 0.162 seconds
