Question Hand pointer on mouse over for forum tabs
15 years 8 months ago #89773 by Pottsy
I'm using IE 8 but it should work as I have another forum at www.stmichaelsbasketball.org.au/index.ph...ultmenu=62&Itemid=60
and it works there. I ahve compared settings of the two forums adn cant find a difference.
15 years 8 months ago #89775 by sozzled
Replied by sozzled on topic Setting up Joomla SEO
Pottsy wrote: Thanks for that. I deleted teh current file which was actually empty and renamed the Joomla one to .htaccess but it didn't seem to resolve teh problem.
The information that I posted ( Search Engine Optimisation (SEO) ) should have worked unless your website does not meet the specifications for a Joomla website or your webhost has some other kind of redirect in place, or you are using a third-party SEF product (which I do not see any evidence of). This is a basic Joomla feature and, if you cannot get it to work, you should take the matter further at forum.joomla.org
15 years 8 months ago #89776 by sozzled
Pottsy wrote: I'm using IE 8 but it should work as I have another forum at www.stmichaelsbasketball.org.au/index.ph...ultmenu=62&Itemid=60
The difference between the two websites (and the explanation for the missing hand) is buried in your site template CSS. It's the Artiseer-generated site template that you created. This isn't a Kunena support issue, sorry.
15 years 8 months ago #89778 by Pottsy
THanks for pointing me in the right direction. I search for my answer there.
