Question Kunena 1.5.12 - 1.6.3 upgrade problem
I downloaded the pack, and i used the install joomla menu. The install process tel me :
Migrate database and files from Kunena 1.5.12. or Install Kunena 1.6.3. . I choise the upgrade and appear a error:
Uncaught Exception: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM AUTO_INCREMENT=12 DEFAULT CHARACTER SET utf8 COLLATE utf8_general_ci' at line 9 SQL=CREATE TABLE `jos_kunena_version` ( `id` int(11) NOT NULL AUTO_INCREMENT, `version` varchar(20) NOT NULL, `versiondate` date NOT NULL, `installdate` date NOT NULL, `build` varchar(20) NOT NULL, `versionname` varchar(40) DEFAULT NULL, PRIMARY KEY (`id`) ) TYPE=MyISAM AUTO_INCREMENT=12 DEFAULT CHARACTER SET utf8 COLLATE utf8_general_ci
What i need to do?
JTS-post Diagnostic Information wrote: Joomla! Version: Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 18:00 GMT
configuration.php: Writable (Mode: 666 ) | Architecture/Platform: Windows NT 6.1 ( i586) | Web Server: Apache/2.2.17 (Win32) PHP/5.3.5 ( localhost ) | PHP Version: 5.3.5
PHP Requirements: register_globals: Disabled | magic_quotes_gpc: Disabled | safe_mode: Disabled | MySQL Support: Yes | XML Support: Yes | zlib Support: Yes
mbstring Support (1.5 or above): Yes | iconv Support (1.5 or above): Yes | save.session_path: Writable | <br />
<font size='1'><table class='xdebug-error' dir='ltr' border='1' cellspacing='0' cellpadding='1'>
<tr><th align='left' bgcolor='#f57900' colspan="5"><span style='background-color: #cc0000; color: #fce94f; font-size: x-large;'>( ! )</span> Notice: Undefined index: executionError in C:\wamp\www\public_html\post.php on line <i>540</i></th></tr>
<tr><th align='left' bgcolor='#e9b96e' colspan='5'>Call Stack</th></tr>
<tr><th align='center' bgcolor='#eeeeec'>#</th><th align='left' bgcolor='#eeeeec'>Time</th><th align='left' bgcolor='#eeeeec'>Memory</th><th align='left' bgcolor='#eeeeec'>Function</th><th align='left' bgcolor='#eeeeec'>Location</th></tr>
<tr><td bgcolor='#eeeeec' align='center'>1</td><td bgcolor='#eeeeec' align='center'>0.0146</td><td bgcolor='#eeeeec' align='right'>935424</td><td bgcolor='#eeeeec'>{main}( )</td><td title='C:\wamp\www\public_html\post.php' bgcolor='#eeeeec'>..\post.php<b>:</b>0</td></tr>
</table></font>
Max.Execution Time: 30 seconds | File Uploads: Enabled
MySQL Version: 5.5.8-log ( localhost via TCP/IP )
JTS-post Extended Information wrote: SEF: Disabled (with ReWrite) | Legacy Mode: Disabled | FTP Layer: Disabled | htaccess: Not Implemented
PHP/suExec: User and Web Server accounts are not the same. (PHP/suExec probably not installed)
PHP Environment: API: apache2handler | MySQLi: Yes | <br />
<tr><th align='left' bgcolor='#f57900' colspan="5"><span style='background-color: #cc0000; color: #fce94f; font-size: x-large;'>( ! )</span> Notice: Undefined index: executionError in C:\wamp\www\public_html\post.php on line <i>541</i></th></tr>
</table></font>
Max. Memory: 128M | Max. Upload Size: 200M | Max. Post Size: 100M | Max. Input Time: 60 | Zend Version: 2.3.0
Disabled Functions:
MySQL Client: mysqlnd 5.0.7-dev - 091210 - $Revision: 304625 $ ( latin1 )
(1) Support for PC-hosted websites (e.g. WAMP, XAMPP)
(2) K 1.6 Technical Requirements
(3) K 1.6 Upgrade Guide
There is not much that we can do to help you with a "website" that you are hosting on your own PC.
Open file
/install/model.php
under Admin Kunena folder, find this function:
protected function migrateTable
Basically, this function recreate a table from an old table's structure. So it uses old syntax.
After this row (or any similar row):
$create = preg_replace('/COLLATE [\w\d_]+/', '', $create);
add:
$create = str_replace(" TYPE=", " ENGINE=", $create);
Do not reload the error page on your web browser; instead, go back and click again on migrate button.
This should work.
