Question Help with avatar upload problems
15 years 8 months ago #88237 by routsounmanman
Hello, everyone!
I just downloaded and installed Kunena 1.6.3 on my 1.5 Joomla! portal and everything is running smoothly and I love it so far. One important mistep, though:
Whenever I try to upload a new avatar image, I get the message:
[...] JFile::copy: Cannot find or read file: 'C:\WINDOWS\Temp\ [...]
Clearly, kunena is misconfigured to use the C:\WINDOWS\TEMP folder instead of the universal Joomla! one. However, I saw no such option in Kunena config and a small search in the code yielded no results, plz help me :-)
Thanks in advance,
Nikos Roussounelos
15 years 8 months ago #88256 by xillibit
Kunena uses default Joomla! things, cna-you put here please your Kunena report configuration ?
15 years 8 months ago #88302 by Matias
The issue is in your WAMP settings. Kunena copies the file from the place where PHP uploads it.
