Question RSS Problem
15 years 9 months ago #86177 by thug_boy
RSS Problem was created by thug_boy
I've problem with RSS feeds
you can see the problem here
www.6olabjo.com/forum?func=rss
I'm using joomla 1.5 - K 1.6.3
*Search Engine Friendly URLs = ON
*mod_rewrite = ON
*Add suffix to URLs = OFF
15 years 9 months ago #86216 by xillibit
Replied by xillibit on topic Re: RSS Problem
You have javascript puted in your rss whic broke it, you need to find which plugin is put it this code in rss :
<script language="JavaScript" charset="utf-8"> // remote scripting library // (c) copyright 2005 modernmethod, inc var sajax_debug_mode = false; var sajax_request_type = "GET"; var sajax_target_id = ""; var sajax_failure_redirect = ""; function sajax_debug(text) { if (sajax_debug_mode) alert(text); } function sajax_init_object() { sajax_debug("sajax_init_object() called..") var A; var msxmlhttp = new Array( 'Msxml2.XMLHTTP.5.0', 'Msxml2.XMLHTTP.4.0', 'Msxml2.XMLHTTP.3.0', 'Msxml2.XMLHTTP', 'Microsoft.XMLHTTP'); for (var i = 0; i < msxmlhttp.length; i++) { try { A = new ActiveXObject(msxmlhttp[i]); } catch (e) { A = null; } } if(!A && typeof XMLHttpRequest != "undefined") A = new XMLHttpRequest(); if (!A) sajax_debug("Could not create connection object."); return A; } var sajax_requests = new Array(); function sajax_cancel() { for (var i = 0; i < sajax_requests.length; i++) sajax_requests[i].abort(); } function sajax_do_call(func_name, args) { var i, x, n; var uri; var post_data; var target_id; sajax_debug("in sajax_do_call().." + sajax_request_type + "/" + sajax_target_id); target_id = sajax_target_id; if (typeof(sajax_request_type) == "undefined" || sajax_request_type == "") sajax_request_type = "GET"; uri = "http://www.6olabjo.com/forum?func=rss"; if (sajax_request_type == "GET") { if (uri.indexOf("?") == -1) uri += "?rs=" + escape(func_name); else uri += "&rs=" + escape(func_name); uri += "&rst=" + escape(sajax_target_id); uri += "&rsrnd=" + new Date().getTime(); for (i = 0; i < args.length-1; i++) uri += "&rsargs[]=" + escape(args[i]); post_data = null; } else if (sajax_request_type == "POST") { post_data = "rs=" + escape(func_name); post_data += "&rst=" + escape(sajax_target_id); post_data += "&rsrnd=" + new Date().getTime(); for (i = 0; i < args.length-1; i++) post_data = post_data + "&rsargs[]=" + escape(args[i]); } else { alert("Illegal request type: " + sajax_request_type); } x = sajax_init_object(); if (x == null) { if (sajax_failure_redirect != "") { location.href = sajax_failure_redirect; return false; } else { sajax_debug("NULL sajax object for user agent:\n" + navigator.userAgent); return false; } } else { x.open(sajax_request_type, uri, true); // window.open(uri); sajax_requests[sajax_requests.length] = x; if (sajax_request_type == "POST") { x.setRequestHeader("Method", "POST " + uri + " HTTP/1.1"); x.setRequestHeader("Content-Type", "application/x-www-form-urlencoded"); } x.onreadystatechange = function() { if (x.readyState != 4) return; sajax_debug("received " + x.responseText); var status; var data; var txt = x.responseText.replace(/^\s*|\s*$/g,""); status = txt.charAt(0); data = txt.substring(2); if (status == "") { // let's just assume this is a pre-response bailout and let it slide for now } else if (status == "-") alert("Error: " + data); else { if (target_id != "") document.getElementById(target_id).innerHTML = eval(data); else { try { var callback; var extra_data = false; if (typeof args[args.length-1] == "object") { callback = args[args.length-1].callback; extra_data = args[args.length-1].extra_data; } else { callback = args[args.length-1]; } callback(eval(data), extra_data); } catch (e) { sajax_debug("Caught error " + e + ": Could not eval " + data ); } } } } } sajax_debug(func_name + " uri = " + uri + "/post = " + post_data); x.send(post_data); sajax_debug(func_name + " waiting.."); delete x; return true; } // wrapper for whatru function x_whatru() { sajax_do_call("whatru", x_whatru.arguments); } function do_save(status) { document.getElementById('whatrudiv2').innerHTML = status; } function wrugetTextBox() { document.getElementById("whatrudiv2").style.display = 'none'; document.getElementById("whatrudiv1").style.display = ''; } function wrusaveStatus(id, uname, defaulttext){ var status; document.getElementById("whatrudiv1").style.display = 'none'; document.getElementById("whatrudiv2").style.display = ''; status = document.getElementById("statusText").value; //uncomment the line below to enable utf8 encoding, you also need to adjust the field length of cb_rustatus in comprofiler table of your joomla database because it is limited to 255 characters status = convertChar2CP(status); x_whatru(id, uname, status, defaulttext, do_save); } function wruclearStatus(id, uname, defaulttext){ var status; document.getElementById("whatrudiv1").style.display = 'none'; document.getElementById("whatrudiv2").style.display = ''; document.getElementById("statusText").value = 'is'; status = document.getElementById("statusText").value; x_whatru(id, uname, status, defaulttext, do_save); } function convertCP2DecNCR ( textString ) { var outputString = ""; textString = textString.replace(/^\s+/, ''); if (textString.length == 0) { return ""; } textString = textString.replace(/\s+/g, ' '); var listArray = textString.split(' '); for ( var i = 0; i < listArray.length; i++ ) { var n = parseInt(listArray[i], 16); outputString += ('&#' + n + ';'); } return( outputString ); } function convertChar2CP ( textString ) { var haut = 0; var n = 0; CPstring = ''; for (var i = 0; i < textString.length; i++) { var b = textString.charCodeAt(i); if (b < 0 || b > 0xFFFF) { CPstring += 'Error ' + dec2hex(b) + '!'; } if (haut != 0) { if (0xDC00 <= b && b <= 0xDFFF) { CPstring += dec2hex(0x10000 + ((haut - 0xD800) << 10) + (b - 0xDC00)) + ' '; haut = 0; continue; }else { CPstring += '!erreur ' + dec2hex(haut) + '!'; haut = 0; } } if (0xD800 <= b && b <= 0xDBFF) { haut = b; } else { CPstring += dec2hex(b) + ' '; } } CPstring = CPstring.substring(0, CPstring.length-1); return convertCP2DecNCR(CPstring) ; } function dec2hex ( textString ) { return (textString+0).toString(16).toUpperCase(); } </script> <link rel="stylesheet" type="text/css" href="components/com_comprofiler/plugin/user/plug_cbwhatareyoudoing/whatru.css">
15 years 9 months ago #86288 by thug_boy
Replied by thug_boy on topic Re: RSS Problem
Thank you for reply..
I found the plugin, its CP plugin and I remove it but the RSS still not working :(
15 years 9 months ago #86423 by Matias
Replied by Matias on topic Re: RSS Problem
I think I found very easy fix for this issue.. When you load rss, try to add &format=rss into your rss url and report if you are still having issues.
15 years 9 months ago #86472 by thug_boy
You mean like this ??
www.6olabjo.com/forum?func=rss&format=rss
it still not working :(
how I can report issue ??
15 years 9 months ago #86496 by xillibit
