Question Max Signature Setting not working
15 years 9 months ago - 15 years 9 months ago #85735 by sasuke
Hi ^^
I find bug in the max signature setting.
I left the max signature value in default setting (300 char).
But apparently i realized some users have a signature with more than 300 characters in length. I tried to change my own signature, and yes, i can have a signature with more than 300 char.
Please check the link : ireborn.us/forum/44-Heart-to-Heart/3057-Say-It-Loud.html
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 40M | Max file upload: 20M
Joomla default template details : jp_dailypraise2_j1.5 | author: www.joomlapraise.com | version: 2.0.1 | creationdate: 02/15/10
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Enabled (Version : 1.6.0-RC2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.0-RC2)
Last edit: 15 years 9 months ago by sasuke.
15 years 9 months ago #85736 by sozzled
It's difficult to know whether you have found a bug or you have been able to exploit a bug. I can't be sure. From personal experience, I've never tried to create a signature that has more than 300 characters; it's probably because that is the way it's always been in Kunena all the way back to Fireboard days. But whether this is something that has not been properly attended to, I don't know, and whether it causes operational difficulties that is also something I'm unaware of, too.
What I can say, in response to your configuration report, is that we would recommend that you upgrade to K 1.6.3 and that you, likewise, upgrade Kunena Login 1.6.2 and Kunena Search 1.6.2 if you are using those things.
15 years 9 months ago #85738 by sasuke
thanks sozzled, i will try to update my kunena first
