Question Problem with Public Access Level for Category
15 years 9 months ago #85618 by kevin90
Hey guys,
with the newest version (1.6.3) I got an issue with the access level of one category.
I selected "Editor" and choosed "No" when asked about allowing subgroups to access the category.
Before upgrading that totally worked out as intented, but now members of the group "publisher" can see this category also, although they should not concerning to the settings.
So I think this is a bug.. .Any idea to fix this?
Thanks and Regards
Kevin
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 40M | Max file upload: 32M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 1.2.0 | creationdate: 02/02/10
Third-party components: AlphaUserPoints: Installed (Version : 1.5.10) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: The file doesn't exist uddeim.j15.xml !
Third-party SEF components: sh404sef: Installed (Version : 2.1.9.787) | ARTIO JoomSEF: Disabled or not installed | AceSEF: Disabled or not installed
15 years 9 months ago #85707 by sozzled
Your K 1.6 configuration report shows
I suggest that you search for this in the forum. This usually happens when people have part-installed J! 1.6.
You also have sh404SDEF installed. sh404SEF is a known cause of many problems that users have reported. A recommendation - although you are not obliged to follow the advice - is to uninstall sh404SEF to see if this improves matters. I hope you try the suggestion and let us know if it works.
If you do not use uddeIM on your website, disable the integration option on your Kunena configuration.
15 years 5 months ago #96880 by kevin90
Hi together,
a few months later the problem gets serious now, because we need this separation with the different access levels and one access level should be allowed to view what the other levels write (in certain categories).
There is no part-installation of J! 1.6 und UddeIm totally runs fine, I don't know why there is this error message in the Kunena config information.
sh404SEF we have uninstalled too, but the problem still exists. Any other ideas? Am I really the only one who got that problem!?
Thanks and regards
Kevin
15 years 5 months ago #96883 by sozzled
When you asked this question, 3 months ago, you wrote that you were using K 1.6.3. Please upgrade to K 1.6.4.
Please read Sections, Categories, sub-Categories (Part 2) - advanced setup for special groups
What is the exact text of the "error message in the Kunena config information"? Can we see your K 1.6 configuration report?
15 years 5 months ago #96909 by kevin90
sozzled wrote: When you asked this question, 3 months ago, you wrote that you were using K 1.6.3. Please upgrade to K 1.6.4.
The forum is running on 1.6.4
sozzled wrote: Please read Sections, Categories, sub-Categories (Part 2) - advanced setup for special groups
Thanks for the link. I read that before, and I made the settings according to that page.
A screenshot of the settings for the respective category (in german):
dl.dropbox.com/u/3453979/kunena_screenshot.png
Short translation
"Öffentliche Zugangsebene" - Public Access Level
"Untergruppen berücksichtigen" - Include child groups
"Adminzugangslevel" - Admin Access Level
sozzled wrote: What is the exact text of the "error message in the Kunena config information"? Can we see your K 1.6 configuration report?
Yes, sure:
Third-party components: UddeIm: The file doesn't exist uddeim.j15.xml !
Modules: Kunena Latest 1.6.2
Time to create page: 0.168 seconds
