Question Strange issue with images url
15 years 9 months ago #85508 by audisport
Hi there,
I've a strange issue with Kunena.
When being used kunena, if there is a module (footer) in the template with pics or in post with pics coming from the site (kunena discuss) at first time we come to the page the images are shown correctly, however if we make refresh of the page the url of the images are changed and nothing shown anymore as they appear to have a url like : /forum/28-competitions-pilotes-vags/images/stories/ecurie/grand_joel/joelgrand.jpg instead of /28-competitions-pilotes-vags/images/stories/ecurie/grand_joel/joelgrand.jpg shown the first time...
Really strange...Do you understand my issue, any idea why by doing refresh the adresses add a /forum prior the ur?
Thanks in advance for your support!
15 years 9 months ago #85511 by audisport
Sorry here's my configuration:
htaccess: Exists | PHP environment: Max execution time: 10 seconds | Max execution memory: 96M | Max file upload: 300M
Joomla default template details : ja_anion | author: JoomlArt.com | version: 1.2.4 | creationdate: 08/16/10
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Disabled or not installed
15 years 9 months ago #85513 by audisport
Ok,I've solved this problem by putting the forum SEF at NO and now it works fine...
15 years 9 months ago #85522 by sozzled
That's weird and the solution doesn't seem to make any sense. Seems like there's a problem with the Kunena routing software ... and the point is that it doesn't happen here at www.kunena.org (which uses standard Joomla SEO/SEF)!
15 years 9 months ago #85553 by audisport
Hi Sozzled,
normal here in the forum you don't have any image coming from a module or and image coming via kunena discuss from a site item.
This appears only in those 2 cases.
For the moment that's the only solution that I found to solve the problem, if you see any other idea where I could look, that would be great!
Thanks again!
15 years 9 months ago - 15 years 9 months ago #85679 by audisport
The problem was finally not only with kunena but also with all internal images in the site...
I'm facing huge SEF issues when refreshing the page all the internal pics change their url and do not appear...I'm quite lost, still searching...
Last edit: 15 years 9 months ago by audisport.
