Question SEF-Problem
15 years 9 months ago #85175 by UdoZ
SEF-Problem was created by UdoZ
setup:
- Joomla 1.5.22 (German) with
-- SEF -> yes
-- mod_rewrite -> yes (default .htaccess set)
-- add suffix -> yes
- Kunena 1.6.3 (German)
-- SEF -> yes
-- Category IDs -> no
-- UTF-8 -> no
After installation I've got the 'standard' problems (403 error, redirection error). After deletion of all Kunena menus, SEF is working fine. Example: my_site/component/kunena/2-maengel/2819-luftstandheizung-defekt.html
Following a suggestion found here, I recreated the Kunena menus using Create Menu in the Control Panel. That leads to a 403 error, when I try to open the forum, call any category or forum entry. SEF stopps working :-(
After deletion of the Kunena menu everything is working fine again.
What do I have to do to get SEF and the Kunena menu working together?
UdoZ
15 years 9 months ago #85179 by UdoZ
Replied by UdoZ on topic Re: SEF-Problem - Solved
Problem was solved by removing the deleted menus from the Menu Trash before the Create Menu action.
UdoZ
Time to create page: 0.097 seconds
