Important Problem with video size
15 years 8 months ago - 15 years 8 months ago #87466 by kitepascal
had the same problem! My videos had a max width of 405px! width=590 had no effect.
You can either set the variable $vid_maxwidth manually...
Insert
$vid_maxwidth = 590; $vid_maxheight = 480; // max. display size
in line 829 (after , /components/com_kunena/lib/kunena.parser.php
or (better solution ;) ):
Set Textarea Width in Frontend configuration to a higher value!
The video max width. will be 90% of this value... :silly:
Hope this helps...
BUT...
in my forum the textareas on post reply and quick-reply were always wider than 450px, so where does this setting take effect??
THX to the Kunena Team for the great work! No problems yet except this little one... :whistle:
Feature! ;)
Viele Grüße
Pascal
Last edit: 15 years 8 months ago by kitepascal.
15 years 1 month ago #108217 by thezone
Replied by thezone on topic Re: Problem with video size
The below,
or (better solution ;) ): Set Textarea Width in Frontend configuration to a higher value! The video max width. will be 90% of this value... :silly:
REALLY WORKS, I PROMISE YOU. I SET MINE TO 900 AS MY SITE IS 1000 WIDTH and tried inserting video.. BAM it works!
Thanks for this... Thanks a LOT!
I would like to be able to just simply paste a youtube linke
And have it show up larger, like 640 x 480. instead of the default, 320x240 or what ever it is.
That would make life SO much easier.
Does anyone know how to edit Joomla or the Forum so that happens? :dry:
kitepascal wrote: Hello,
Insert
Hope this helps...
BUT...
Feature! ;)
Viele Grüße
Pascal
15 years 1 month ago #108219 by 810
Replied by 810 on topic Re: Problem with video size
"components\com_kunena\lib\kunena.parser.php" line 781
regards 810
