Question Problem with "userlist" functions
15 years 10 months ago #82052 by joseorozcozuluaga
I have a problem with kunena 1.6.2 that I could not resolved.
I have installed in a server of a shared hosting the Joomla's version 1.5.22 (english) from the package of installation of joomla.
Then I have installed the packages of lenguage for Greek language.
Later I have wanted to install Kunena version 1.6.2. Several attempts finished with installation error after creating the tables.
Then I decided to copy my sub-folders com_kunena of the folders administrator and components. And I
exported my local database and installed it in the hosting.
Everything seemed to work correctly. I have been working with Kunena without problems.
Till now that I have detected a problem with everything related with "userlist". All the links that use this function produce the " rename failed " error
I have installed the database of production in my place and it works correctly.
Can someone have some idea of the problem?
15 years 10 months ago #82053 by xillibit
Can-you give an acces to you site to see the issue ?
15 years 10 months ago #82056 by joseorozcozuluaga
Hello xillibit,
www.managaia.gr/index.php?option=com_kun...ultmenu=55&Itemid=53
Κατάλογος χρηστών (Users list)
Σύνολο χρηστών: 3 (users on line)
I can change the language if you need it
Thank you very mucy
15 years 10 months ago #82059 by xillibit
Can-you put here please your kunena configuration settings ?
15 years 10 months ago #82065 by joseorozcozuluaga
Hello Xillibit:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 16M | Max file upload: 5M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
15 years 10 months ago #82169 by joseorozcozuluaga
Xillibit, hello
Have you found anything in the settings? I realise now att I have de same problem in the administration when I click in the User Manager even I can see the user list.
Thank you
