Question System SEF Plugin Enabled Issues?
15 years 10 months ago - 15 years 10 months ago #81732 by DavidB
I hope someone can help. :(
My site is FastPitchVA.com
I have the Joomla system SEF plugin enabled. Joomla version 1.5.22
Kuena version 1.6.2
The problem I have is that when I have the SEF plugin enabled then there is no way for anyone to create a profile as all the profile menu items are not working. Also, Google maps stops working in posts.
If I disable SEF then Kuena works properly but then my template breaks. :ohmy:
I had this problem with both 1.6.1 and 1.6.2
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 200M
Joomla default template details : magz_plazza | author: TemplatePlazza.com | version: 1.0 | creationdate: 03/01/2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Any ideas?
Thanks!
David
Last edit: 15 years 10 months ago by DavidB.
15 years 10 months ago #81771 by DavidB
I have attached the following image and I hope that helps someone to see what I am needing help on. Thanks in adavance!
15 years 10 months ago #81787 by DavidB
I have found a work around.
I attached a different Joomla template to the Kuena forum by going into the Joomla template manager, choosing the rhuk_milkyway template and assigning this template to only the Kuena forum. My default template is still used for the rest of my site.
I hope this might help someone else who is having the same problem. :)
