Question Problems with RSS
15 years 11 months ago #78189 by darksoul
Problems with RSS was created by darksoul
I can't see RSS!!
This problem is visualized!
Errore interpretazione XML: la dichiarazione XML o testuale non è all'inizio di un'entità
Indirizzo: www.samples-share.com/it/forum/rss
Linea numero 1, colonna 5: <?xml version="1.0" encoding="UTF-8"?>
and there the kunena configuration. i need to solve the problem.
I'm using CB 1.3.1, Kunena 1.6.1
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 64M | Max file upload: 64M
Joomla default template details : yoo_phoenix | author: YOOtheme | version: 1.5.20 | creationdate: January 2010
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.0)
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Disabled or not installed
15 years 11 months ago #78198 by xillibit
Replied by xillibit on topic Re: Problems with RSS
1°) You should have a joomla! plugin which introduce some blank space, so try do disable all joomla! plugins and re-enable them one by one by testing each time if the rss works
2°) In the kunena configuration panel, set joomla plugin support on disabled
15 years 11 months ago #78227 by darksoul
Replied by darksoul on topic Re: Problems with RSS
There was a CB plugin who generate the problem. Tank Xillibit
