Question Slow load in Kunena 1.6.1
- turminator
- Junior Member
15 years 10 months ago #73179
by turminator
Slow load in Kunena 1.6.1 was created by turminator
I have installed Kunena 1.6.1 into my webcommunity and I look that there is a very slow load (more than 10 seconds to load). Is very strange because with Kunena 1.5.11 loads correctly.
www.nudos.org/Ver-foros/
Can help me?
Many thanks!
Can help me?
Many thanks!
15 years 10 months ago #73419
by xillibit
Replied by xillibit on topic Re: Slow load in Kunena 1.6.1
Look the source code of you page and check what javascript is loaded.
Disable all modules and plugins, and enable them one by one by checking each time if it's affect the load time of the page
- turminator
- Junior Member
15 years 9 months ago #74953
by turminator
Replied by turminator on topic Re: Slow load in Kunena 1.6.1
Hi xillibit,
Thanks for your reply. I look it and I don't find any strange javascript. I try to disable some pluggin but this effect persist. It's strange because I have got installed a new plugin or component since Kunena update process.
Can you help me a little?
Many thanks!
Many thanks!
15 years 9 months ago #74955
by misterpat
Replied by misterpat on topic Re: Slow load in Kunena 1.6.1
Just a thought as it was slowing down my forum. If You use any SEF components, try disabling them and see if it speeds up. I used to use ACESEF, ditched it and now my site is fast. :woohoo:
- turminator
- Junior Member
15 years 9 months ago #75217
by turminator
I disable SH404SEF and slow speed persists. I don't know what more things I can do.
15 years 9 months ago #75248
Replied by sozzled on topic Re: Slow load in Kunena 1.6.1
Your website loads a bucketload of Javascript libraries! If you read
Mootools 1.2.4
you will see that Javascript library conflicts can sometimes plays a part in slow loads of Kunena.
In your case your website loads two different Javascript libraries named mootools.js:
(1) /templates/myblogv2/src/mootools.js
(2)/plugins/system/mtupgrade/mootools.js
The second one is the one that's needed and used by Kunena. From the little bit of searching that I did, myblogv2 was around in December 2008. There's a fairly good chance that whatever customised Javascript was used in this Joomla extension is incompatible with Joomla 1.5.22 (or whatever version of Joomla you are using). See what happens if you eliminate myblogv2.
You are also using jQuery (as part of JomSocial). The version of JomSocial you are using may also be a contributing factor.
Can you please post your K 1.6 configuration report? Thank you.
Time to create page: 0.245 seconds
