Question Massive amount of sql queries with components sef urls enabled.
15 years 11 months ago #72176 by misterpat
Hello all,
With the sef urls enabled in AceSEF with the components router, I'm getting a massive server load with about 200 plus sql queries. I tried the acesef extention and had more problems, so i went back to the components router.
Any ideas how to reduce these sql queries?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : subblack | author: dragmen | version: 1.1 | creationdate: 11/11/2008
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
15 years 11 months ago - 15 years 11 months ago #72178 by misterpat
Debug with sef off.
Last edit: 15 years 11 months ago by misterpat. Reason: edit info
15 years 11 months ago #72179 by sozzled
G'day, misterpat, and welcome to Kunena.
Although I don't have a specific answer for you, you may find the information posted in this topic useful: K 1.6 sh404SEF stops Thank You, RSS feeds, PDF and message previews from msg #13 and following.
15 years 11 months ago #72181 by misterpat
Here is with debug on and component router. Wierd thing. The sql queries went down, but time to render page is through the roof!
15 years 11 months ago - 15 years 11 months ago #72182 by misterpat
sozzled wrote: G'day, misterpat, and welcome to Kunena.
Same to You Sozzled!
I found the information I needed to read in that post and just pulled the plug on acesef.
BTW,
Former PhpBB3/JFusion user, converted to Kunena. Best choice I made for my site! Keep up the great work!
Time to create page: 0.152 seconds
