Question Problems with menus, messages not displaying, reinstalling Kunena, browser errors ...
16 years 12 hours ago - 15 years 11 months ago #72107 by thiru_ch
i am new to this forum. I have a website www.myreadingroom.co.in . in that i installed this forum. i am getting problem in the forum when i make any changes. the different problems
1. When i set a menu option to display index directly. then it displays that link is not properly configured.
2. when i clicked on the topic that is not displaying the messages.
3. then again i am reinstalling the component again.
4. and i am getting the following errors when i clicked any option. the details are
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; GTB6.5;
SIMBAR={11923EA3-F693-4D8F-84D4-B2626A530E7A}; SLCC1; .NET CLR 2.0.50727;
Media Center PC 5.0; InfoPath.2; .NET CLR 3.5.30729; .NET CLR 3.0.30618)
Timestamp: Mon, 29 Nov 2010 08:56:10 UTC
Message: 'this.element' is null or not an object
Line: 1
Char: 69614
Code: 0
URI: myreadingroom.co.in/plugins/system/mtupgrade/mootools.js
Message: Object doesn't support this property or method
Line: 1
Char: 47606
Code: 0
5.I am using joomla 1.5 template.
and also suggest me about the basic configuration for kunena.
Any help would be greatly appreciated.
Last edit: 15 years 11 months ago by sozzled. Reason: Changed subject to reflect the contents of the topic
16 years 5 hours ago #72137 by xillibit
Replied by xillibit on topic Re: about mootols
Can-you put here please your kunena configuration settings ?
16 years 49 minutes ago #72165 by sozzled
G'day, thiru_ch, and welcome to Kunena.
I am having a few problems understanding the several different issues that you seem to be experiencing. Can we take each problem separately please. If we bundle all the problems together we will not get any fast results ... and you want fast results, right? ;)
Which of these four problems is the most important and that needs to be fixed first? Please do as xillibit has suggested and provide you K 1.6 configuration report .
I think the least of your problems concerns Mootools 1.2.4 (but I could be wrong).
15 years 11 months ago #72226 by thiru_ch
Replied by thiru_ch on topic about mootols
Thank you for your reply. may be the follwoing is the configuration report
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.0-RC2)
if the above is not the configuration then tell me how to post configuration
15 years 11 months ago #72227 by thiru_ch
actuallay i am new to this forum. my first problem is
now i am also sending my configuration report also
15 years 11 months ago - 15 years 11 months ago #72228 by thiru_ch
Replied by thiru_ch on topic about mootools problem
and i am getting the following errors when i clicked any option in IE but it wont shows any error in Firefox browser
Line: 1
Char: 69614
Code: 0
Line: 1
Char: 47606
Code: 0
Last edit: 15 years 11 months ago by thiru_ch.
Time to create page: 0.165 seconds
