Question Move Post Issue
15 years 11 months ago - 15 years 11 months ago #71828 by Troneas
Move Post Issue was created by Troneas
my forums are displaying the author of the post as the one who moved it instead of the moderator who actually moved the topic.
So instead of having Moved By: (name of moderator who moved the post)
i get
Moved By: (name of the OP)
how can i fix this?
Joomla default template details : game_crusade | author: Shape5.com | version: 1.0 | creationdate: December 2009
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Installed (Version : 1.2.2) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC3) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
Last edit: 15 years 11 months ago by Troneas.
15 years 11 months ago #72256 by xillibit
Replied by xillibit on topic Re: Move Post Issue
This is a known issue and it will be fixed in k1.6.2
15 years 10 months ago - 15 years 10 months ago #81203 by Troneas
Replied by Troneas on topic Re: Move Post Issue
just a heads up still not working in 1.6.2
thnx.
Last edit: 15 years 10 months ago by Troneas.
15 years 10 months ago #81204 by sozzled
Replied by sozzled on topic Re: Move Post Issue
I don't understand the problem.
The author of the post is always the author of the post.
Let's see if we can properly understand the issue.
Q: When does the caption "moved by" appear?
A: When you move a topic by leave a "shadow copy" behind.
Is my answer right or not right? Please let me know so that I can properly understand the problem and how to reproduce the symptoms of the problem. Thanks.
15 years 10 months ago #81205 by Troneas
sozzled wrote: I don't understand the problem.
the problem is when a moderator moves a post - the "moved by:" will show the name of the author of the post, instead of the moderator who moved the post.
and yes, it happens when you leave a shadow copy behind.
15 years 10 months ago #81207 by sozzled
Thank you. Yes, you are quite right. Look at www.kunena.org/playground/main and you will see the topic "test today" which I moved that shows the wrong information.
Evidently there needs to be a bit more work done to solve this issue. :laugh:
