Question Forum Inside a Frame
16 years 1 week ago #70722 by sgprs
Forum Inside a Frame was created by sgprs
Any ideas why Kunena would be appearing inside a frame? I have scroll bars on the side and bottom. This didn't happen until I upgraded to the latest 1.6.1 update. I checked css and all looks good, plus, nothing has changed... just did the upgrade.
Any ideas?
Thanks!
16 years 1 week ago #70724 by fxstein
Replied by fxstein on topic Re: Forum Inside a Frame
Please provide your config report.
This is most likely a conflict with your main template.
Thx!
16 years 3 days ago #71196 by sgprs
Replied by sgprs on topic Re: Forum Inside a Frame
Sorry about that. I just forgot to include it. Here it is. Thanks for the reply!
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 512M
Joomla default template details : SGPRS | author: iWeb Media Services, LLC. | version: 1.2.1beta | creationdate: 04.07.2010
Third-party components: AlphaUserPoints: Installed (Version : 1.5.11) | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
16 years 3 days ago #71201 by sozzled
Replied by sozzled on topic Re: Forum Inside a Frame
If you run IE8 without compatibility mode on then you won't see the scroll bars. If you view the forum with Firefox you won't see the scroll bars. If you use Google Chrome you won't see the scroll bars. This is an IE7 issue.
