Question [Solved] Problem with a swedish language file.
16 years 1 month ago - 16 years 1 month ago #65561 by lammet
Hi.
I found a Swedish language file and saved it under Language/sv-SE.
The text looks like it should but an annoying white space come over the text.
Why?
BR
Jukka
Last edit: 16 years 1 month ago by lammet.
16 years 1 month ago #65624 by Matias
Hei Jukka,
Language strings should not cause anything like this, but if it is language, you should check if there's something wrong with HTML (caused by language strings). Do other languages work, Finnish? ;)
There can also be issues in your CSS or you can have some JavaScript that causes this.. Hard to know without seeing the site.
16 years 1 month ago - 16 years 1 month ago #65641 by lammet
Thanks for replying Matias.
Switched back to the English language file an i get the error with that one also.
Will double check the suggestions you gave me.
BR
Jukka
Edit: It is a template issue. Switched to the example template an all look fine now.
16 years 1 month ago - 16 years 1 month ago #65645 by Mortti
I think the problem isn't in the language files (I just tested english, finnish and swedish without any kind of problem quickly)... which button set do you use in Kunena? Or maybe conflict with your Joomla! template? Can you quickly test with Joomla! default template rhuk_milkyway ?
I take Swedish translation from here: www.kunena.com/forum/107-translations/64...for-kunena-160#64770 ... ( I also just done that package possible to install direct via joomla installer because I'm lazy to move language files as there txt is told... ;) :
Svensk översättning av Kunena 1.6.0
Denna mapp innehåller följande filer
/administrator/language/sv-SE/sv-SE.com_kunena.ini
/administrator/language/sv-SE/sv-SE.com_kunena.install.ini
/administrator/language/sv-SE/sv-SE.com_kunena.menu.ini
/language/sv-SE/sv-SE.com_kunena.tpl_default.ini
/language/sv-SE/sv-SE.com_kunena.tpl_example.ini
Och denna textfil Kunena 1.6.0
Dessa filer skickar du upp med en FTP client
EDIT: Problem already solved...
Last edit: 16 years 1 month ago by Mortti.
16 years 1 month ago #65650 by lammet
Thanks.
The link is very appreciated. Found my file at Svenskajoomla.. Yours is spot on.
M.v.h. Jukka
16 years 1 month ago - 16 years 1 month ago #65655 by Mortti
I reply on that topic and you also found there that my little edited Swedish package whick can install quickly... tell also svenskjoomla.se if you can write in Swedish well... I can't :laugh:
The following user(s) said Thank You: lammet
