Question [Solved] Problem with a swedish language file.
Language strings should not cause anything like this, but if it is language, you should check if there's something wrong with HTML (caused by language strings). Do other languages work, Finnish?
There can also be issues in your CSS or you can have some JavaScript that causes this.. Hard to know without seeing the site.
Switched back to the English language file an i get the error with that one also.
Will double check the suggestions you gave me.
BR
Jukka
Edit: It is a template issue. Switched to the example template an all look fine now.
I take Swedish translation from here: www.kunena.com/forum/107-translations/64...for-kunena-160#64770 ... ( I also just done that package possible to install direct via joomla installer because I'm lazy to move language files as there txt is told...
Svensk översättning av Kunena 1.6.0
Denna mapp innehåller följande filer
/administrator/language/sv-SE/sv-SE.com_kunena.ini
/administrator/language/sv-SE/sv-SE.com_kunena.install.ini
/administrator/language/sv-SE/sv-SE.com_kunena.menu.ini
/language/sv-SE/sv-SE.com_kunena.tpl_default.ini
/language/sv-SE/sv-SE.com_kunena.tpl_example.ini
Och denna textfil Kunena 1.6.0
Dessa filer skickar du upp med en FTP client
EDIT: Problem already solved...
The link is very appreciated. Found my file at Svenskajoomla.. Yours is spot on.
M.v.h. Jukka
