- Thank you received: 1
Question Site sooo slow after upgrade to Kunena 1.6... Help
xillibit wrote: Hello,
Do you have looked this topic : www.kunena.com/forum/168-k-16-support/63...er-javascript-issues
Yes I've seen that. I managed to get the BB code editor back. I added the mootools.js file from the upgrade plugin to my yootheme template in the js library. This seemed to allow it to work without slwoing the site down to snail pace. The one thing I do still get is the error - Kunena: You have a plugin that uses Mootools 1.1 or custom version of JHTMLBehavior.
Many features, including Quick Reply and BBCode editor may be broken.
Please enable System - Mootools Upgrade plugin.
Any way to disable the error?
I think perhaps the two files were conflicting with eachother, causing the site slowness.
therang wrote: Thought it was too good to be true. Now my backend menu doesn't work (Site, Menus, Content... etc). Great!!
Ok I disabled the mootools upgrade plugin and the backend menu now works. Any idea how I can disable the Kunena warnings/alerts on the frontend? I would be happy to display this as the forum is now working fine due to some mootools hacking in the template.
It can be disabled from administrator/com_kunena/libraries/template.php around line 82 and 87.
