Question conflict issue (i think) please help
- tonyworship
- Junior Member
my issue:
I first installed the forum and it worked fine
Then i started installing other applications on to my joomla site.
now when members visit their personal page, they can't upload pictures or click on any personal settings, nothing works. I tried disabling some stiff but got no where.
I was wondering, can i please give you my personal info so you can go into the site and take a look inside and please tell me whats wrong??? can i email you with password info?
my site is www.lowaltitudewarfare.com feel free to make an account and see if you have an issue uploading etc..
thanks in advance!
tony
tried to register, but even that is broken. You have too much stuff loaded.
I recommend you disable/uninstall jbolo and soundmanger. My guess is that one of them is causing all the java script errors on your site (even outside of Kunena).
Hope this helps!
PS: Cool looking site!
- tonyworship
- Junior Member
I uninstalled jbolo a while ago, didnt help.. but i never installed anything called soundmanager.. don't know what that is. here are some pics of my installations
modules: i52.tinypic.com/2a5dugl.jpg
components: i51.tinypic.com/2sacpbt.jpg
anything look weird in here from your experience?
thanks
t
Try to disable that.
In general I recommend you use Firefox with Firebug or Chrome with its built in Developer tools to look at the javascript log. It tells you all the scripts that are being loaded. One of them is causing your sitewide issues.
Hopt this helps!
- tonyworship
- Junior Member
but the forum still doesn't work.
let me go do the tasks you gave me, be right back.
- tonyworship
- Junior Member
I dont know java script, to be honest, i wouldnt even know what i'd be looking at....
plugins: i54.tinypic.com/2yv2f68.jpg
thanks you!
