Question Problem with Kunena 1.60 Stable and K2
16 years 1 month ago #64129 by Cmueller
Hi Guys, greetings from Germany
First sorry for my English... :)
My Problem with Kunena is that the plugin ( system-K2 ) the BBcode Toolbar from the Forum Topic Editor deactivates
And i have got a Issue message from Kunena when the system K2 Plugin is activated :
Kunena: You have a plugin that uses Mootools 1.1 or custom version of JHTMLBehavior.Many features, including Quick Reply and BBCode editor may be broken.
Which Version of Mootols uses K2 ?
Anyone have an Idea how I fix this Problem ?
My Homepage Config :
K2 2.4.1
Kunena Stable 1.60
Joomla 1.5.20 Stable
JomSocial 1.8.8 Stable
Joomla!-Version: Joomla! 1.5.20 Stable [ senu takaa ] 18-July-2010 18:00 GMT
Template :RT Dominion 1.5.4
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 40M | Max file upload: 20M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.8) | UddeIm: Disabled or not installed
16 years 1 month ago - 16 years 1 month ago #64146 by Cmueller
How can I enabled/disable plugins only on certain pages that I want?
Like for modules i know how to do that.. What about plug ins?
PLS Help Me
Last edit: 16 years 1 month ago by Cmueller.
16 years 1 month ago #64180 by Matias
Plugins are always loaded -- in every page. But there may be way to fix this: find System - Mootools Upgrade plugin and make sure that it's listed first -- at least before K2 system plugin.
16 years 1 month ago #64210 by Cmueller
this plugin is in my configuration disabled, is there a other solution ?
16 years 1 month ago #64213 by Cmueller
ok i have make system mootools upgrade first and enabled it .... done but the bbcode toolbar is still missing when system k2 is enabled :(
Matias wrote: Plugins are always loaded -- in every page. But there may be way to fix this: find System - Mootools Upgrade plugin and make sure that it's listed first -- at least before K2 system plugin.
16 years 1 month ago #64226 by ferdash
I'm having the exact same issue, I've changend the plugin order so that system-k2 comes after mootools-upgrade, but if i disable the mootools upgrade (wich should be that way) the sistem loads the old mootools from /media/system/js/mootools.js
I don't know what to do.
