Question An invalid post ID was requested
15 years 10 months ago #82744 by baijianpeng
Recently I updated a Kunena 1.5.x forum to Kunena 1.6.2, then I noticed that guests can NOT see new posts posted after this migration, only can see old posts.
When guests trying to open a newly post, there will be a message:
But after login in, registered members can see that post.
I had read above posts on this topic, and tried to disable SEF option, but this problem not solved.
Can you give me some help?
Thanks.
www.joomlagate.com/
Chinese Joomla Users' Portal
The topic has been locked.
15 years 10 months ago - 15 years 10 months ago #82746 by sozzled
baijianpeng wrote: Can you give me some help?
As you can see, this topic was created 4 months ago and it related to K 1.6 RC2. K 1.6 RC2 is not supported. We should have archived the topic but the topic was kept open to allow the person who started it to reply. The person who started this topic has not responded to our questions.
May I ask why you chose this particular topic to report your problem? Have you read Search Engine Optimization (SEO) and do you completely understand how to properly configure SEO? We appreciate it when people are willing to help the project correct defects with Kunena but it really would help us a lot more if you would assist by giving us your K 1.6 configuration report when you post your questions in the Support category.
This category is for Kunena version 1.6 issues only. For a faster response, please make sure you include your K 1.6 configuration settings report in your posts. We do NOT support test versions. Before asking for support, please read the guides posted as sticky topics in this category.
Please do not use this category to ask for help if K 1.6 does not work for you in the same way as it works here at this website. Please do not use this category to request a change to the standard behaviour of Kunena.
For a faster response - a response that might help you better - please include your current K 1.6 configuration report.
I understand that you have "an invalid post ID was requested" and there have been dozens of topics that have been written that address this issue. Why did you choose this one?
The issue involves SEF URLs and it depends on how you have implemented Search Engine Optimization on your website.
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago #82748 by baijianpeng
I searched "An invalid post ID was requested" on Google and came here. Sorry I did not noticed that there are other topics with the same subject.
My forum is version 1.6.2 stable.
Well, could you please help to split my former post from this old topic and merge it into other topics concerning v1.6.2? (of course you have to delete this post to make discussion clean)
Thanks.
www.joomlagate.com/
15 years 10 months ago #82749 by sozzled
We really need to see your current K 1.6 configuration report before we can help you.
15 years 10 months ago #82750 by baijianpeng
Yes, I should paste my configuration there.
Now it is:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.0)
Third-party SEF components: sh404sef: Disabled or not installed | ARTIO JoomSEF: Installed (Version : 3.7.6) | AceSEF: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
Thank you.
www.joomlagate.com/
15 years 10 months ago - 15 years 10 months ago #82751 by sozzled
Uninstall completely ArtioSEF and all your Kunena problems will disappear.
Time to create page: 0.161 seconds
