Question Script Error/IE7+ Problems
16 years 2 months ago #60542 by thetoast
Some of my website users are having either Script errors or Loading problems. Needless to say these people are using IE7. I see no problems while using Firefox.
The error says something along the lines of. "A script on this website is causing your browser to run slow, if it continues your computer my become unresponsive"
Or when they click on the forums their browser just locks up.
16 years 2 months ago #60543 by sozzled
thetoast wrote: The error says something along the lines of. "A script on this website is causing your browser to run slow, if it continues your computer my become unresponsive"
What is the script, running on your website, that is "causing your browser to run slow"?
16 years 2 months ago #60546 by thetoast
how would i find this out? cause i wouldnt know where to begin.
16 years 2 months ago - 16 years 2 months ago #60549 by sozzled
Do you get the same symptoms using IE7 to view the pages at Kunena.com? If you don't get the same errors it's fairly obvious that you have something running on your website that IE7 has objections with. IE7 can probably give you the specifics. Because I don't use IE7 so I can't really help you here - but perhaps someone else can - unless we knew more about your website.
Can you answer that question: Do you get the same symptoms using IE7 to view the pages at Kunena.com?
16 years 2 months ago #60550 by thetoast
IDK cause i don't use IE7.
But i do at work, so i could check tomorrow.
Where would i find the script error if it comes up?
16 years 2 months ago #60560 by sozzled
First of all, answer my question which is intended to see whether the problem is a general Kunena problem or whether it's a problem that is only related to your website. Thank you.
