Question Some minor problems
16 years 2 months ago - 16 years 2 months ago #60388 by ralfakerkhoff
just installed RC2 on my site:
wwww.pixel-wonders.de
I have noticed some problems:
1.In profile settings the user is able to change his password to 1 character.
2. Changing the avatar with the default ones that came with the installation works fine.
Changing the avatar to a larger image results in a:
open_basedir restriction in effect. File(/tmp) is not within the allowed path(s): )
in /var/html/Joomla/components/com_kunena/lib/kunena.file.class.1.5.php
An open_basedir warning depending on the size of an image ?
Any tips are welcomed
Ralf
Last edit: 16 years 2 months ago by ralfakerkhoff.
  • marshalrosy
  • marshalrosy's Avatar
  • New Member
  • New Member
16 years 2 months ago #60416 by marshalrosy
Replied by marshalrosy on topic Re: Some minor problems
Hi
I think there is something wrong happened during installation. I would suggest you to once uninstall and the reinstall it. It might help you.
16 years 2 months ago #60445 by ralfakerkhoff
it can't be the installation. The problem is reproducable on a local fresh Jommla installation, on an existing local site and on the live site.
The 1 char password possibility occurs in Kunena 1.5 too.
Cheers
Ralf
16 years 2 months ago #60462 by xillibit
Replied by xillibit on topic Re: Some minor problems
1°) I don't know what's the password length minimal in Joomla! ?
2°) I have already seen sometime this issue. I think that your hoster has some securities things enabled which limit the avatar upload.
Can-you please put here the report configuration : www.kunena.com/forum/168-k-16-support/56...-when-asking-support
16 years 2 months ago #60477 by ralfakerkhoff
the minimum password lenght is 4 characters by default.
I'll check the security settings later at home.
Cheers
Ralf
16 years 2 months ago #60517 by ralfakerkhoff
it must really be the size of the avatars. Converted all avatars to 64x64 and the problem is gone
