Important forums keep going offline
14 years 10 months ago - 14 years 10 months ago #116251 by mayhem2277
Hi folks,
the forums that i run for a Clan gaming site keeps going offline. i have reinstalled them and the site works fine for 4-5 days then the forums go offline again .
Here are the Report Configuration Settings:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : gored_ultra_lernvid.com-j1.6 | author: Juergen Koller | version: 1.0 | creationdate: Apr 2011
Kunena default template details : Integrity Pro Kunena 1.6 Template | author: www.TemplateKunena.com | version: 1.6.4 | creationdate: 2011-06-01
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.5
Third-party SEF components: ARTIO JoomSEF: The file doesn't exist sef.xml ! | AceSEF: The file doesn't exist acesef.xml !
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | My Kunena Forum Menu 1.7.0 | My Kunena Forum Posts 1.7.0 | Kunena Groups 1.7.0
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.7.1 | Kunena Login 1.6.4
Here are the error logs:
[Sun Jan 22 10:28:25 2012] [error] [client 86.40.232.116] PHP Warning: array_search(): Wrong datatype for second argument in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/plugins/system/jotcache/jotcache/autoclean.php on line 30, referer: www.brtd.net/
[Sun Jan 22 10:29:16 2012] [error] [client 86.40.232.116] PHP Warning: file_put_contents(/usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/administrator/cache/com_admintools.updates.ini): failed to open stream: Permission denied in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/libraries/joomla/filesystem/file.php on line 359, referer: www.brtd.net/administrator/index.php?option=com_admintools
[Sun Jan 22 10:29:23 2012] [error] [client 86.40.232.116] File does not exist: /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/favicon.ico
[Sun Jan 22 10:37:10 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45, referer: www.brtd.net/home
[Sun Jan 22 10:37:10 2012] [error] [client 86.40.232.116] File does not exist: /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/favicon.ico
[Sun Jan 22 10:37:13 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45
[Sun Jan 22 10:37:14 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45
[Sun Jan 22 10:37:15 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45
[Sun Jan 22 10:37:16 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45
[Sun Jan 22 10:37:34 2012] [error] [client 86.40.232.116] File does not exist: /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/favicon.ico
[Sun Jan 22 10:37:40 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45, referer: brtd.net/forums
[Sun Jan 22 10:37:40 2012] [error] [client 86.40.232.116] File does not exist: /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/favicon.ico
[Sun Jan 22 10:37:41 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45, referer: brtd.net/home
[Sun Jan 22 10:37:43 2012] [error] [client 86.40.232.116] PHP Fatal error: Call to undefined method Kunena::getVersionInfo() in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/components/com_kunena/lib/kunena.version.php on line 45, referer: brtd.net/forum5-outfit-chat7-hello-and-welcome
[Sun Jan 22 10:37:43 2012] [error] [client 86.40.232.116] File does not exist: /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/favicon.ico
[Sun Jan 22 10:40:11 2012] [error] [client 66.249.72.231] PHP Warning: array_search(): Wrong datatype for second argument in /usr/local/pem/vhosts/149639/webspace/siteapps/28968/htdocs/plugins/system/jotcache/jotcache/autoclean.php on line 30
I have uninstalled jotcache as it was throwing a lot of error in the log file.
Hopefully you can help me with fixing this error
Last edit: 14 years 10 months ago by mayhem2277.
14 years 10 months ago - 14 years 10 months ago #116274 by sozzled
G'day, mayhem2277, and welcome to Kunena.
The errors were caused by the Joomla extension JotCache: see Problem component JotCache with Kunena 1.7.1 . It sounds like it was a good idea to uninstall that extension.
Your other problem (about the forum going offline) I'm not sure about. It could have something to do with the Kunena template you are using. Do you have the same issues if you use the Blue Eagle template? If you do not have those problems with the Blue Eagle template then you should not use the Integrity Pro Kunena 1.6 which was not developed by the Kunena project team and which was designed for an older version of Kunena. You should probably ask the author of the Integrity Pro Kunena 1.6 if they have made an update for that template.
You seem to have issues with your Kunena menu - which is a Joomla menu. Please read How do I restore my Kunena menu? in order to fix your Joomla menu.
You are using two different extensions for generating SEF URLs: ARTIO JoomSEF and AceSEF and these will probably conflict with one another and with Joomla SEO. I would remove both of them while you are working through your problems.
You do not need My Kunena Forum Menu 1.7.0, Kunena Forum Posts 1.7.0 or Kunena Groups 1.7.0 - all of these are wrong for K 1.7.1 - unless you are using JomSocial. You have not installed JomSocial and therefore you should uninstall those things.
You should also upgrade Kunena Discuss and Kunena Login - the versions you have installed are also wrong for K 1.7.1 0- if you are using those modules. See the download page.
I'm not sure what you mean by your "forums going offline". Do you get a message that says "Forum is offline for maintenance"?
Last edit: 14 years 10 months ago by sozzled.
14 years 10 months ago - 14 years 10 months ago #116298 by mayhem2277
HI SOZZLED,
currently I am using acesef seo extension , I did use the artio seo in the past but had login and captcha issues with it, so uninstalled it and deleted the directory's.
I don't use the kunena menu . it is working as is,
I have updated the login and latest modules
to explain the situation better: every 4-5 days the forums go offline(Forum is offline for maintenance), the rest of the site stays online and responds quickly to requests. no errors have shown in the logs when i looked ,the site is lock down with 755 directory 644 file permissions . the only fix is to reinstall the forums .
I'm the only user with access to the back-end. I haven't set the forums offline or anything.
I do appreciated your help in helping me find a fix for this annoying error
14 years 10 months ago #116303 by CheechDogg
So what just happened to your site right now is what happens ?
I just went back to your site to check on the thread I posted on your forums, and it shows me the "This site is down for maintenance. Please check back again soon." message.
[img
Find me on Facebook.
14 years 10 months ago #116308 by sozzled
Our approach is always to start with a known, reliable basis. ARTIO JoomSEF complicates issues. If you have issues when you use that extension, you need to contact the ARTIO JoomSEF developers; we know very little about their work.
If you search this forum in relation to problems that people have had with ARTIO JoomSEF you will find that this is not something that people have enjoyed trouble-free. I'm not saying that this is the cause of the problem but it would be sensible to eliminate this from the software soup that might be responsible for the problems that you may be having.
If you don't want to use the Kunena menu, in the way that it's designed to work, that's OK, too. But you should have a good understanding of how Joomla works and what is the recommended advice we've given in relation to using Customised menus .
This is primarily a community-driven, self-help forum. We'll do our best but, if people want to do things in their own particular way, it may take longer to give you the help that you're after. I suggest we start by establishing that your site works, first, without the clutter I've pointed to. Have you made the changes I recommended? If you were to post your configuration report now, would it be any different?
14 years 10 months ago #116318 by mayhem2277
hi cheechdog,
i was cleaning out some stuff on the site, so i turned it offline for 20-30mins, i was also installing the updated login and discuss kunena modules, so that why the forums were offline
i have disabled the acesef seo, i haven't used the artio joomsef in 2-3 months , i have cleaned out the cache and turned off other unneeded modules .
Modules: Kunena Latest 1.7.1 | Kunena Stats 1.7.1 | Kunena Login 1.7.1
thanks for your help so far btw
Time to create page: 0.191 seconds
