Question Having some problems with Kunena
15 years 1 week ago #111215
by Espeed
Having some problems with Kunena was created by Espeed
Alright so I'm having quite a few issues with Kunena and I really want to use it for my site.
My site is www.zioinc.com/
I'm using Joomla 1.5.24
I'm having 3 major problems and I have some other questions as well.
1.) The first problem I'm having and I'm not sure if it's a problem or not but in the back end of my site it's showing COM_KUNENA and the sub menus of that component are showing COM_KUNENA_CONFIGURATION etc, is this what it's supposed to look like?
2.) I'm having problems with the Module for Kunena that's shows that links to the forum, the Kunena Menu wasn't showing any links unless I put it in Legacy mode so I deleted the module and I made my own but i'd like to have the original menu back and working instead of just trying to string it together myself. Any ideas on how to reinstall this?
3.) Whenever a user is logged in and they try to save their updated avatar or profile information it takes me back through my JWHMCS login and takes me back to the front page of my website, this is extremely irritating.
Any help would be greatly appreciated I have SEF Component and I have everything associated with Kunena disabled in the component.
The topic has been locked.
15 years 1 week ago #111222
by Matias
Replied by Matias on topic Re: Having some problems with Kunena
1) Your language is probably missing some translations, what language do you use? Try if K1.7.1 (downloads page) helps you -- if not, you probably need to add some translations in Transifex (
www.transifex.net/projects/p/Kunena/
2) What is the module name? You mean latest?
3) Some SEF components may have some issues with Kunena. But I don't think that this is SEF issue; it sounds more like you're having an user plugin that for some reason wants to take the control (what happens if you disable JWHMCS login?).
15 years 1 week ago - 15 years 1 week ago #111230
by Espeed
Replied by Espeed on topic Re: Having some problems with Kunena
Well I downloaded 1.7.1 and did the uninstall, then I uploaded 1.7.1 again and did a fresh install.
1.) I use the english language and I have uninstalled the kunena component completely and checked to see if it's still in the FTP and it's not and then reinstalled kunena 1.7.1 and I'm still getting the first problem.
2.) Forum Menu or Kunena Menu. It's the menu that has all the links to the forum itself. Index...recent topics..etc Still the same problem it's just showing up with the title and a white space below no links..
3.) I disabled JWHMCS and now I get a red bar at the top of the page and it says COM_KUNENA_ERROR_TOKEN.
Now I have a 4th and 5th problem.
4.) In the back end for Kunena I see two links Statistics and Settings and they are offset text that cant be clicked that are over top of the regular links on the left hand side.
5.) The template looks bad because the minimize button at the top of the forum is half hidden.
Ex: www.zioinc.com/index.php?Itemid=362
I really don't like the way the forum links are coming directly off the index.php it's not good for SEF or SEO is there a way to change this?
Last edit: 15 years 1 week ago by Espeed.
15 years 1 week ago #111233
Replied by sozzled on topic Re: Having some problems with Kunena
I'm locking this topic for the following reasons:
(1) The subject "Having some problems with Kunena" does not describe the nature of the problem(s). Please read the posting guidelines printed at the top of this page especially when you create a topic in the Support category.
(2) Before posting your questions, please read the FAQs (see the menu at the top of this page) that may already answer your questions.
(3) We ask that you create a separate topic for each question that and that you give the topic a meaningful subject.
(4) When posting to the Support , please make sure that you include your Kunena configuration report.
From our experience, asking one question at a time and using a meaningful subject, will not only help us better to help you but it will also greatly assist others looking for answers to similar problems that they may have.
