Question Problem with space between line, the text line can not be read
The following post is regarding a problem I got in my kunena, the problem is this: when someone uses a size greater than 5 for the letter, the text is inserted and the two lines are joined as you can see here: 216.250.115.93/foro/5-off-topic/66-agrad...imit=10&start=30#810
Sure you say is your joomla template, but it is not, use firebug, I tried everything according ccs editing we recommend firebug but nothing.
actually switch to using the original template joomla and nothing that has the problem yet.
Information on my website:
PHP Version: 5.3.8
Web Server: Apache
Version of Joomla: Joomla! 1.5.23 Stable [taka loves Zenua baji] 04-March-2011 18:00 GMT
Installed version: 1.7.0 Kunena | 29/08/2011 | 5135 [Tale]
Kunena Template: Default
Joomla Template: YT_Neo_v5.5.16_J1.5
You've found a problem and I have an easy solution: don't use text sizes greater than 5 when posting messages over several consecutive lines. If you really need to use text sizes greater than 5 in "normal" use then you will need to change the line-height that affects every message posted in your forum. Add the following rule to the end of your Joomla site template:
You need to change the PHP source code to remove that option from the BBcode menu; I don't know the name of the file that you need to change. Sorry.
As you can see, using large text sizes is not a problem with the forum at this website. People don't use large text sizes. Ask yourself why is that? The answer is that people don't waste their time playing with different font settings.
Give it time. Your forum is new and people are still playing with its features. After a while things will settle down and this will be "yesterday's problem" that no one will remember.
