Question [SOLVED] cb_downloadtabs plugin causes problem with Kunena RSS feeds
15 years 3 weeks ago - 15 years 3 weeks ago #110224 by fichier
hello,
I have a problem with RSS feeds of Kunena. (rss of other components work)
they are not displayed, I get this instead of rss:
screen copy
w3c Feed Validation Service say feeds are not valide:
This feed does not validate.
line 1, column 4: XML parsing error: <unknown>:1:4: XML or text declaration not at start of entity
<?xml version="1.0" encoding="utf-8"?>
any idea please ?
thank you
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 96M | Max file upload: 40M
Joomla default template details : ja_t3_blank | author: JoomlArt.com | version: 1.1.6 | creationdate: 22 July 11
Third-party components: CommunityBuilder 1.7 | UddeIm
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.7.0 | Kunena Discuss 1.7.0
Modules: Kunena Latest 1.7.0 | Kunena Stats 1.7.0 | Kunena Login 1.7.0 | Kunena Search 1.7.0
Last edit: 15 years 3 weeks ago by sozzled. Reason: Changed subject to improve relevance for search purposes
15 years 3 weeks ago #110230 by xillibit
Replied by xillibit on topic Re: problem with RSS feeds
Try to disable Joomla! support plugin, in Kunena configuration panel
15 years 3 weeks ago #110232 by fichier
Replied by fichier on topic Re: problem with RSS feeds
hi,
thanks for your answer
i always tried, joomla plugins are disabled in kunena config.
15 years 3 weeks ago #110453 by fichier
problem solved!
it was a plugin for CB (cb_downloadtabs) that displays files sent by the user with Remository in a CB tab.
there was a blank line at end of php file of the plugin.... :whistle:
Time to create page: 0.146 seconds
