Bug [Problem assumed resolved - no response from user] Title of Kunena forum posts says only "Forum"
14 years 11 months ago #109920 by vickyjain05
Hi Sozzled,
The SEO page link was not very useful. Following is the configuration of my kunena 1.6
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 50M
Joomla default template details : cs_terapanth | author: Prinka Jain | version: 1.0.0 | creationdate: 07/03/11
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.2.0) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Enabled (Version : 1.6.4) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
14 years 11 months ago #109922 by sozzled
I'm glad I asked for your configuration report.
K 1.6.3 is not supported (therefore you will have to resolve yourself any quesitons you have about that version). If you want help you should upgrade to K 1.7.0 and, likewise, upgrade any Kunena add-on products to the corresponding version.
Legacy mode is strongly not recommended - not because legacy mode itself causes problems (well, most of the time it doesn't) but because J! 1.0 extensions that rely on legacy mode usually result in websites falling over constantly. See the important advice we have written about using Legacy mode . Basically, get rid of it.
K 1.7 provides improved SEF capability. I think that's the key to answering your question. I hope this helps.
14 years 11 months ago #109973 by vickyjain05
I just recently upgraded to kunena 1.7.0 one of our client's forum, but after that they had started receiving spam messages even though the recaptcha plugin was configured properly. So, I am a bit hesitating to do that on www.terapanthnetwork.com .
I think I should fix the issue myself, I went through the router.php file, but did not find anything wrong there..Can you suggest me which files shall I look at?
Any help shall be greatly appreciated....
thanks
14 years 4 months ago #123800 by sozzled
Time to create page: 0.236 seconds
